Help!!!!!!!!!!!!!!!!
I have a '96 S14 with a huge timing prob.i built a new engine which is stock only with a upgraded torbo.on the cars standard timing (15 deg) it wouldnt even race the engine up to 2000 Rpm's.But on bout 45 deg .....
or so it go's.And there is no sighn's or sounds of the engine giving a PING sound.So Plz help...! [/img]
With our cars (S14 and S13 I think) you need to remember wasted spark, ie the spark plugs fire in batches of 2, Cyl 1 and 3 fire at the same time and 2 and 4 at the same time, all that happens is when Cyl 1 is at combustion then Cyl 3 is sparking an exhaust gas mixture. I dunno why they do that... any ways if you use a timing light that you can set the degrees on with the wheel at the back you need to double the degrees, if you're looking for 15 degrees, you set the light to 30 etc etc.
If you use the conventional light where you aim at a timing mark then I dont think you have this problem the light just "seems" dimmer as its flashing once at the timing mark and once 180degreed the other side of the mark.
veecee wrote:i'm not sure what you mean about "doubling degrees"
Coz the induction loop you run the timing light off "sparks" twice as much as it should, ie cyl 1 sparks when cyl 1 is at TDC and when cyl 3 is at TDC...
Both S13 and S14 do NOT run wasted spark they run sequential ignition as standard.
The Nissans will not rev over 2 or 2.5 if the maf is disconnected but they sound very sick and backfire etc.
its the difference between the CA and SR FSM then!!!
because i read the manual, then read it again, then made sure, then had somebody else check it, etc, etc, etc... because the induction loop method is very easy compared to the HT lead method.
lol!
jo14 - did you come right man?
Sokar wrote:With our cars (S14 and S13 I think) you need to remember wasted spark, ie the spark plugs fire in batches of 2, Cyl 1 and 3 fire at the same time and 2 and 4 at the same time, all that happens is when Cyl 1 is at combustion then Cyl 3 is sparking an exhaust gas mixture. I dunno why they do that... any ways if you use a timing light that you can set the degrees on with the wheel at the back you need to double the degrees, if you're looking for 15 degrees, you set the light to 30 etc etc.
Thanks for the clarity Duane, but what does this mean? is the method of "doubling" the degrees on an advanced timing light incorrect? Or if it is correct then why do you do that?
I dont know why you had to double the timing because if you use the timing loop or else just hold the inductive pickup on the cyl 1 coil the timing light works exactly like a conventional car.
Well boykies i used that loop method.i set my light to 30 deg and on the pully it gave me 15 deg.so if thats right, i dont know!?!?!?!?!?!?
one thing i noticed was that when i start my car in the mornings it idles very smooth, but once it reaches Warm up conditions it sounds a bit rough and doesnt idle that smooth.
