S13 Front disks
S13 Front disks
Does anyone know where to get cheap or what other car uses the same?
I paid R150 a disk but turns out I have the smaller disks, same as primera or almera not sure. Measure it and match it at a brake shop.
The brakes I fitted are called alpha.
Richard
Post by Richard »
The 91 sx uses the same disk as the Almera, the smaller one. There is an Alpha branch in JHB, call them and ask them to send you a parts catalogue, you can then try and match up a disk.
300sx
0.8 Bar Boost
Post by 300sx »
there is an almera that uses the same size as the big brake sx's 280mmx22 , also there is a maxima that uses same size, but 5 stud, will have to redrill for 4.. as said above, download alfa.co.za cat. and compare..
300zx fairlady 1991
200sx s13 with vg30det @ 1bar
shot guys
PiCo Performance
disc
Post by PiCo Performance »
combi caravelle discs work great
Re: disc
PiCo Performance wrote:combi caravelle discs work great
same disk just 5 hole?
Re: disc
Yeah, you'll have to get it re-drilled
Re: disc
hehe Welcome back dude!
