Competition Clutches & FW - SR20DET & DE **IN STOCK*
Wanted or for sale
JDMWORX
Post by JDMWORX »
Hi Guys
I will have the following Competition Clutches & Flywheels in-stock and on the shelf in the next month +-
This will be the re-launch deal for CC in SA .
The 1st 15 Clutch kits sold will recieve included in below prices
Free Competition Clutch T-shirt
Free Delivery country-wide
Nissan SR20DET
2100 - Stage 2 - Street Series 2100 Clutch Kit - R4400.00
This assembly provides an estimated 80% increase in torque capacity and is properly suited for aggressive street use and moderate track use. The Carbon Kevlar material with its alloy backing matched to a performance pressure plate will provide smooth engagement and extended life. 500 mile break-in highly recommended with this set-up. 300 mile break-in REQUIRED with this set-up. (Some kits may not be supplied with all pieces. Please verify with Competition Clutch before ordering).
The 2100 Series kit includes a performance pressure plate, a high torque sprung disc with antiburst steel backed Carbon Kevlar facings, all applicable bearings, and the appropriate alignment tool.
1620 - Stage 4 - Strip Series 1620 Clutch Kit - R4400.00
This assembly, available with a double spring, six rivet carriage is good for ease of gear transition with higher horsepower. This disc complimented by a performance pressure plate provides 250% increase in torque capacity. 300 mile break-in recommended with this set-up.
The 1620 Series kit includes a performance pressure plate, a six puck high torque sprung disc with Ceramic buttons, all applicable bearings, and the appropriate alignment tool.
SR20DET - R3000.00
ULTRA LIGHTWEIGHT STEEL FLYWHEEL - STU
The STU flywheel is recommended for forced induction and/or track and rally racing applications. This flywheel will work with ALL performance and stock clutch assemblies.
Qualities of the CCI Ultra Lightweight Steel Flywheel:
One piece ring gear for high durability
Weight varies from 8 lbs. to 10 lbs. depending on application
Well suited for Stage 3 and up clutch kit applications
Stamped with 4140 plate with 2000 ton pressure at 1260 degrees
CNC machined and balanced to O.E. specifications
Reduced Mass = Increased Accleration
Meets and exceeds SFI 1.5
Or Take a Clutch & Flywheel Combo for R7000.00
NISSAN 350Z STAGE 2 CLUTCH KIT - R5500.00
NISSAN SR20DE [STI] STAGE 1 = R3000.00
NISSAN SR20DE [STI] STAGE 2 = R3200.00
SR20DE STU FLYWHEEL = R2800.00
RB25DET
Stage 2 - Carbon Kevlar -----------R4400.00
Stage 3 - Segmented Kevlar-------R5000.00
Stage 4 - 6 Pad Ceramic-----------R4400.00
Stage 4 - 6 Pad Rigid Ceramic-----R4400.00
Stage 5 - 4 Pad Ceramic-----------R4400.00
Stage 5 - 4 Pad Rigid Ceramic----R4400.00
Stage 6 - 6 Pad Ironman ----------R5000.00
Ultralite Flywheel ------------------R3200.00
ALL ABOVE EXCEPT RB25 WILL IN STOCK IN +- 1 MONTH, STOCKS WILL BE LIMITED SO YOU ARE WELCOME TO CONFIRM YOUR ORDER PRIOR DELIVERY TO SECURE THIS GREAT DEAL AND AWESOME PRICING
Hayden - 0842466527
jdmworx@gmail.com
COMPETITION CLUTCHES & FLYWEELS WILL BE AVAILABLE SHORTLY FOR
HONDA B/D/H & S2K
NISSAN SR20DE & SR20DET
SUBARU WRX & STI
TOYOTA X-RSI & 20V
mailto: jdmworx@gmail.com or Hayden - 0842466527
http://www.jdmworx.co.za
Anything nice for a 370Z cosmetic wise?
RudeBoy
Post by RudeBoy »
lotta peeps on here need descent RB25 clutches
JDMWORX
Post by JDMWORX »
RudeBoy wrote:lotta peeps on here need descent RB25 clutches
Thanks for the heads-up
Well then here they go, they gotta shout if they want it prices below and updated above, i obviously don't have stock but will bring them in at these prices.
RB25DET
Maybe you guys wanna look at a Group Buy, i will pass on a nice Discount off this pricing :wink:
HONDA B/D/H & S2K
SUBARU WRX & STI
TOYOTA X-RSI & 20V
JDMWORX
Post by JDMWORX »
PLEASE NOTE THAT THE SR20DET & SR20DE CLUTCHES & FLYWHEELS ARE IN STOCK AND READY TO DELIVER ANYWHERE IN SA ...
DELIVERY TAKES 1 DAY :wink:
HONDA B/D/H & S2K
SUBARU WRX & STI
TOYOTA X-RSI & 20V
antman
Engine: VG
Real Name: Tony
Post by antman »
Hi, do you stock flywheel/clutch for 300zx?
Thanks
JDMWORX
Post by JDMWORX »
antman wrote:Hi, do you stock flywheel/clutch for 300zx?
Thanks
Hi There
No, we don't and never will keep them IN Stock as Shelf Items, as there is to few of them around... :cry:
We can ORDER them for you and it takes 2 weeks , the last Stage 2 300zx i supplied was done this way, You can speak to Evano on this site, he can vouch for this in a 300ZX and can Voucn for the SR20DET Stage 4 & Stage 2, as both him and his brother has them...
Anyway here is pricing on the 300ZX Twin Turbo 89-96
STAGE 1 - R3600.00
STAGE 2 - R4800.00
STAGE 3 - R5400.00
STAGE 4 - R4800.00
STAGE 5 - R4800.00
Flywheels for TT
Ultralite = R3700.00
Street Lite = R3100.00
300ZX Non Turbo - 90-96
STAGE 1 - R3200.00
STAGE 2 - R4500.00
STAGE 3 - R5400.00
STAGE 4 - R4500.00
STAGE 5 - R4500.00
Flywheels for Non Turbo
Ultralite = R3600.00
Streetlite = R3400.00
If you interested let me know, im sending a order through for 350Z and S2000 & New Type R's tommorow, will be able to get you clutch in less than 2 weeks, providing they have stock, and im sure they do have :wink:
HONDA B/D/H & S2K
SUBARU WRX & STI
TOYOTA X-RSI & 20V
Evano 200sx
Newbie
clutch/flywheel
Post by Evano 200sx »
hey guys the clutch and flywheel from jdmworks is very good and he will not let you down when it come too service , i have been dealing with him for a very long time now and the pricing is the best around and the parts dont take long to get to you .i run a stage 2 clutch in the twin turbo z till that was sold and now have stage 4 plus flywheel in both my s14's.and drifting both cars and use one as daily drive.
antman
Engine: VG
Real Name: Tony
Post by antman »
Hey JDMWORX, pretty keen on the 300zx TT flywheel and clutch combo, what is the make and spec on these? Whats the weight on the flywheels?
Also the estimated shipping costs to JHB.
Thanks
JDMWORX
Post by JDMWORX »
antman wrote:Hey JDMWORX, pretty keen on the 300zx TT flywheel and clutch combo, what is the make and spec on these? Whats the weight on the flywheels?
Thanks
Ultralite = 4.5KG's
Please note that Street Lite has been discontinued due to most 300ZX owners opting for the Ultralite.
If you take the combo, i will deliver to JHB Free...
Hayden
0842466527
HONDA B/D/H & S2K
SUBARU WRX & STI
TOYOTA X-RSI & 20V
JDMWORX
Post by JDMWORX »
Ok, not sure how you missed it...
The MAKE is COMPETITION CLUTCH ...The Fastest growing and Best Performance Clutch Brand in the WORLD
www.competitionclutch.com
HONDA B/D/H & S2K
SUBARU WRX & STI
TOYOTA X-RSI & 20V
JDMWORX
Post by JDMWORX »
More 350Z Clutch & Flywheels on its way...Arrival this weekend :wink:
SR20DE & DET in stock and ready to ship
JDMWORX
HONDA B/D/H & S2K
SUBARU WRX & STI
TOYOTA X-RSI & 20V
JDMWORX
Post by JDMWORX »
SR20DET ***SPECIALS***
Take either a STAGE 2 OR STAGE 4 with ULTRALITE FLYWHEEL Delivered anywhere in SA [Closest airport] for...................
........R7000.00
I have IN-STOCK and ready to ship
SPECIAL ONLY VALID TILL 30 APRIL 2010
Hayden - 0842466527
jdmworx@gmail.com
www.jdmworx.co.za
HONDA B/D/H & S2K
SUBARU WRX & STI
TOYOTA X-RSI & 20V
neptune
Post by neptune »
Must say I got good service when we purchased a few B16 stuff.
Will check out some of his sx stuff and RB stuff. :lol:
JDMWORX
Post by JDMWORX »
neptune wrote:Must say I got good service when we purchased a few B16 stuff.
By the time you come, there's gonna be nothing left :lol:
I still have some 2 x Stage 2's and 1 x stage 4 ...for the SR20det , Flywheels are all sold and i will have to order more :arrow:
HONDA B/D/H & S2K
SUBARU WRX & STI
TOYOTA X-RSI & 20V
Locked
