New SX owner, popped gasket
OutOfMyWay
Post by OutOfMyWay »
Hi everybody,
I picked up my S13 this past Sunday, yesterday i was driving home from work when i noticed the temperature gauge starting to climb, when i switched off the car i heard a hissing sound, upon closer inspection, i found that all the water had sprayed out through a leak in the gasket between the head and the intake manifold, do i just need to get the gasket replaced? if so, who can i take it to?
thanks a lot!
OutOfMyWay
I took a pic of where it's leaking from.
poizen
Real Name: Mical Mackay
Post by poizen »
that just looks like a leak from the intake runner and not the block and head so you might just get away from buying a gasket set and replacing the gasket
if it is the block then you need to have the head skimed etc
OutOfMyWay
poizen wrote:that just looks like a leak from the intake runner and not the block and head so you might just get away from buying a gasket set and replacing the gasket
thanks for the repy,
sorry, about saying it's on the block, i wasn't thinking, it's between the head and the bit that the injectors are in.
hentiebez
Post by hentiebez »
if it is between the inlet manifold and the head then you must just get a gasket and fit it yourself, not a very big job :D
OutOfMyWay
hentiebez wrote:if it is between the inlet manifold and the head then you must just get a gasket and fit it yourself, not a very big job :D
It may not be the biggest of jobs, but i'm not very...........mechanically inclined :lol:
poizen
Post by poizen »
well it easy take one 13-15mm socket undo like 8-10 bolts slide off the manifold and pop new gasket in with some good sealer and peplace your bolts where you from
total job should take you lke 2-3hours max
ads
Real Name: Adam
leak
Post by ads »
i can do it for you im situated in roodeport jhb.pm me.
OutOfMyWay
I'm in Benoni,
Problem is i'll have to get the car towed.
hentiebez
Post by hentiebez »
ads are you based across the road from dash sand on main road
ads
Real Name: Adam
o
Post by ads »
no im in robertville around flora center.
OutOfMyWay
so any idea where i can buy the gasket guys? or do i have to buy a whole set?
poizen
Post by poizen »
i bought a whole engin gasket set from alert engin parts for 350
but you cant just buy the head gasket set from them for like 200-250
OutOfMyWay
thanks, dont think there's an Alert near me, I'll check AutoZone,
Do i just ask for a gasket set for a CA18DET?
poizen
Post by poizen »
yes but they will prob only have cor the ca18de not the turbo motor but it identical and is they can find 200sx s13 then ask for the pulsa or sentra
