Wanted: CA motor mounts
- ReeceZ
I need left and right, best condish as possible plz. 072 431 8486
- Speed breeder
- 0.7 Bar Boost
you will struggle to find original...
jag mounts will work unless your motor makes huge power...
i have changed the jag mounts again on mine after a couple of months of driving.
keeps braking in first gear though as soon as the back steps out.
ordered nismo mounts... think i have had enough training/exposure to the task...lol
- Real Name: Nat Wakefield
I've also fitted those R50 special Jag mounts... Please beware that they do not last very long as the centre threaded bolt does not go all the way through the rubber portion. The threaded parts break off.
I've sourced a very good pairt of second have CA ones as mine where completely busted.
Good luck!!!
Good luck!!!
