if that's the case. why don't volvo or golfs even a stock 200sx have that sound? is it because there isn't enough boost by factory spec?
or am I missing something here completely?
I'll take a stab at using my theory and say yes, you have less power under boost than a 1300 N/a has at same RPM. I think its the compression ratio, the lower you go the less power you have under boost; the reverse is also true you can increase your compression and if the dumbass SNS article is anything to go by you get 5% for every .5 compression step up. But 5% doesn't sound right, you wouldn't loose "5%" by dropping compression .5, there must be some science based formula that is more exact.widowmaker wrote:now that your question has an answer you wont mind me hijacking this thread
this also falls under the silly question category
does a N/A car have more power/torque than a turbo car before it boosts? or does it just feel that way coz youre waiting for boost? or is it just a gear ratio question? i havent had much experience in other types of turbo cars
now the running and screaming can start
you know your ring is not a solid round item right and there is this slit that you use to expand the ring to take it over the piston... well the "gapping" is the size of that gap in the slit when it is in the bore... Hope that made senceDaniel wrote:Same here. would like to put them in properlyCharl wrote:Since were on Daniel's rings topic, what does gapping them mean?![]()
