water pump problems need help
hey guys it looks like my water pump is going cause its leaking on the pully i got a SR20 engine now ill this damage my engine or can i ride it for a while and just check that it doesnt overheat
- Speed breeder
- 0.7 Bar Boost
i wouldn't take a chance with the leak...the pumps normally leak to show there is an issue with it...
with the leak, more air will enter the cooling system and your temp sensor wont be able to read the temp of the water.
the more air enters the system, the more inaccurate the temp gauge will be.
and i have tested this...
a car without water in the system will show normal operating temperature
- Speed breeder
- 0.7 Bar Boost
