CAS
Posted: Thu Nov 26, 2009 10:22 am
by Andrew.200SX
Hi 1 and all.
I desperately need a Cam Angel Sensor for my CA18DET.
Changed the lifters and the car wouldn't start, just noticed that I can pull the shaft out of the CAS.
Desperate
Posted: Fri Nov 27, 2009 7:27 am
by poizen
i have a spare but i live in durban
Posted: Fri Nov 27, 2009 7:32 am
by Andrew.200SX
Thanks Bud
I found out yesterday that the engine importers can supply me with one and there is a guy on the forum a couple of clicks away from me that also has 1.
Thanks again anyway.
Before I can do anything , I need to get compression on my engine first after changing the lifters. This engine has baffled me aswell as quite a few mechanics.
Posted: Fri Nov 27, 2009 7:37 am
by poizen
look in your ehaust camshaft where the cas goes in and make sure that the locating tooth is there is it not and you put the cas in a couple of degrees out youll never start it i found that out after few hours
Posted: Fri Nov 27, 2009 7:52 am
by Andrew.200SX
It is there , but if the cam timing is spot on then surely the car must start?
I marked and put the CAS back exactly as I removed it. My biggest problem is the compression. With the new lifters there was a fair amount of compression , but out of desperation I put the old lifters back and there was no compression. So I have now re-installed the new lifters after bleeding them this time. Today is the moment of truth. If there is no compression , I apparently have to remove the head and send it into an engineering shop.
Posted: Fri Nov 27, 2009 7:59 am
by poizen
when you say marked the cas do you mean on the cam belt cover and cas
so you say your cam and cas both had the half moon locators in them mose cams the half moon is broken off i didnt notice it first time but after a while i figured it out
what are your error codes saying
take your cas out and leave the ignition on and then turn the splindle u should hear injectors and spark trying to work
one last thing check the fuel pump fuse (the other day i drove to work all dandy then switched off and when tried to start it would just crank but not fire then found the fuel pump blew its fuse (worth a look into)
also have you made sure you got spark
fuel and spark has to ignite no matter the compression it wont run well or might even keep cutting out but it will backfire or some sign of ignition
Posted: Fri Nov 27, 2009 8:07 am
by Andrew.200SX
I marked the CAS when I removed it from the cam cover, on the cam cover, after setting the crank pulley on TDC and checked to make sure that the cam timing was right after removing the cam cover.
When I replaced the lifters it was trying to start , but to no avail. Maybe the cas was broken then allready.
The first thing that I checked was the fuel pump fuse , becasue I put in a Walbro pump 3 weeks ago and the car wouldn't start and after an hour of frustration , I decided to check the fuse only to find it was blown.
I took out number 1 plug and coil pack the other day and when swinging it fired once , so maybe because of the CAS it wasn't firing when it should ??
I am going to swing her again just now , with the plugs out , the power transistor disconected and without the CAS and check for compression.
I was swinging the crap out of the car for a few days , so that might be when the CAS broke and I only noticed afterwards in the manual that the power transistor must be disconnected when checking for compression , so I hope I haven't cocked that up 2 !
Posted: Fri Nov 27, 2009 9:24 am
by Andrew.200SX
Poizen , am I right in assuming that the car wouldn't start if the CAS' shaft was snapped in half ? or would it have started but with a missfire ?
Posted: Fri Nov 27, 2009 9:28 am
by poizen
would never start if the cas is buggerd so yes you are correct but for it to snap make sure that the cam belt cover has the 2 locating pins in or your cas wont sit directly inline with the cam thus causing strain on the cas mayb even leading it to snap
Posted: Fri Nov 27, 2009 9:49 am
by Andrew.200SX
Locating pins??? I just assumed that if the bolts all line up , that it is right ?!
:shock:
Posted: Fri Nov 27, 2009 10:01 am
by poizen
nope sorry that is incorrrect hahah
there is 2 locating dowls look at this pic mine are missing but gives you idea where they go
this is crutial or when you tighten your cas your timming moves and you mesd around alot (also found out hard way mine only had one in and when i tightend the cas bolts it moved between 7-10 degrees timing
Posted: Fri Nov 27, 2009 10:05 am
by Andrew.200SX
Thanks Bud
Posted: Fri Nov 27, 2009 10:08 am
by poizen
any time least i could do
hope it comes right if not get dicktator/gotech and chuck the sucker out
Posted: Fri Nov 27, 2009 10:10 am
by Andrew.200SX
HA HA
I was wondering if it was needed with a Diktator system.
What about the Nistune management system ? any opinions ?
Posted: Fri Nov 27, 2009 10:12 am
by poizen
you can use it on dicktator or you use the crank pully
nistune looks great and you keep all your tuning tools like afm cas det sensor etc but youll have to tune it yourself
