Before Chuck slaps the big G's out of me lets talk OIL
I know Toby and Nuren is using Castrol RS sinthetic oil, question...as far as I know sinthetic oil is good for a turbo car, but I also know that because our cars is so old and has been around the block a few times, it needs a multigrage oil for the valve seeds.
You guys using RS don't you get problems because of the km's on the car, and if not why?
As far as I can find out any synthatic oil is good for a turbo car, why evrybody seems to go for GTX RS is because of its viscosity, normally the others are sae40 or 10w-40 where RS is 5W-60.... it can handel more heat and cold.
I've never heard of or seen shell helix synthetic oil, I guess it's because I never looked for it, never too old to learn something. Chuck knows everything, what he doesn't know he beats out of you..
WooHaa
- 0.6 Bar Boost
Let me not go thro this lesson again. But just to summarise, The first number is the viscosity of the oil in the cold & the second number is at high heat.
Castrol RS has the higest viscosity at heat, while Mobile has the lowest during start up.
Also remember synthetic oil does get eaten up has much as multigrade & also synthetic oil normally coats the metal a little. It's not like duraLube and all that stuff.
i recommend Mobile One & Castrol RS I have even noticed the engine running quieter when using Mobile 1. & This is on an engine that has 160000km on it..Original.
- Daniel
- Real Name: Daniël
LOLDerek-son wrote:If my car starts pissing oil as Daniel aliquently puts it... I start pissing tears. Chuck will feal embarrest by me but he will get over it.
i was just saying. I noticed considerably more leakage when i went from mineral to synthetic oil. But the seals are tired, the sump gasket was my main concern as that had a little leak. but now it comes out the cam and crank seals and basically everywhere! Cant wait to drop in the other motor and start the rebuild on this one. And another thing, Castrol Edge seems to do the job just fine.
I don't know of the other oils but I can say this, someone I know has the 2l sx, he got the castrol edge as a pressie, few days later he picked up a knock on a bearing, he thinks it's because of the oil but it could just be murphy....
As for the what oil to buy freddy, according to the turbo guys and racing guys gtx rs is the way to go...as for the other oils I recon any synthetic oil is better than normal arganic oil....and Chuck says so too!!!!!
Big_Guns
I doubt that the bearing knock was cos of the oil, maybe the oil change but not because of the oil.Derek-son wrote:I don't know of the other oils but I can say this, someone I know has the 2l sx, he got the castrol edge as a pressie, few days later he picked up a knock on a bearing, he thinks it's because of the oil but it could just be murphy....
He might not have put enough oil into the motor, or else maybe he doesnt have a baffled sump which would cause an oil surge into 1 corner when cornering hard or drifting and cause the bearings without protection to knock.
I recommend Castrol Edge Sport 10w60 or the Mobil 1. But I rate Castrol Edge tops. In my brothers Honda, he revs over 8500 rpm with no oil supply issues.
With SX's or CA18det make sure to check your oil seals. Friend of mine went thru 2 clutch plates because the crankshaft seal kept breaking and so oil leaked into the clutch assembly.
- ChemCool
Clutch Shudder
Can this then also be a reason for clutch shudder or not? Oil leaking into clutch assembly?
