Wanted or for sale
Tobie
Posts: 538 Joined: Mon Jul 27, 2009 11:15 pm
Post
by Tobie » Wed Oct 28, 2009 9:36 am
I have sets of mint condition stock RB26 pistons, the perfect cure for the RB25 guys with soft pistons, the RB26 stock piston is said to be allot stronger than the RB 25 ones.
6x pistons = R1500
Also have some conrods, on the uk site guys run them past 600HP
6x rods = R1500
Tobie on Mon Sep 27, 2010 12:34 am, edited 4 times in total.
ReeceZ
Posts: 1876 Joined: Sun Jan 20, 2008 1:36 am
Post
by ReeceZ » Wed Oct 28, 2009 9:55 am
Rat, buy it!
RB25SX
Posts: 1423 Joined: Tue May 06, 2008 4:38 pm
Post
by RB25SX » Wed Oct 28, 2009 10:26 am
Just if u didnt know, the comp height of the RB26 piston is 1mm lower than RB25. U can use it but comp will be very low, or u will have to skim the block to compensate.
R32 GTR
Posts: 5378 Joined: Sat Jun 30, 2007 10:38 am
Post
by rat » Wed Oct 28, 2009 4:23 pm
i know the RB25 is 9:1 and the RB26 is 8.5:1 so would using the RB26 in a RB25 make it 8.5 or lower?
RB25SX
Post
by RB25SX » Wed Oct 28, 2009 5:38 pm
The rb26 piston compensates for longer crank stroke with a 1mm lower comp hight. Not sure if u will have 8.5:1 if u fit it in RB25. Depends on piston dome volume. If u work out from 8.7:1 less 1mm gives u 8:1 on RB25 (86 bore X 71.7 stroke)(16cc dome, 64cc head), so it might be a bit low. Can compensate with 0.5 off head or block to give 8.3:1
R32 GTR
Post
by rat » Thu Oct 29, 2009 7:45 am
ja that is a bit low but if you get the rb26 crank as well then you are fine
RB25SX
Post
by RB25SX » Thu Oct 29, 2009 8:21 am
rat wrote: ja that is a bit low but if you get the rb26 crank as well then you are fine
Yes, should be fine with crank. RB26 rods are also stronger than RB25 (same lenth).
R32 GTR
Post
by rat » Thu Oct 29, 2009 8:36 am
sorry tobie for the off topic. Thanks rb25sx for the info
Tobie
Post
by Tobie » Thu Oct 29, 2009 9:25 am
No problem, this is good info for future buyers……
So with the lower compression and stronger pistons I guess one could up the boost a bit more.
Tobie
Post
by Tobie » Wed Nov 04, 2009 10:40 am
Tobie on Sat Jan 16, 2010 2:52 pm, edited 1 time in total.
SilviaS13
Club Drifter
Posts: 1287 Joined: Mon Aug 31, 2009 10:56 pm
Engine: 2JZ
Real Name: Ernest Simpson
Post
by SilviaS13 » Tue Nov 10, 2009 2:36 pm
Hello, Were all the pistons sold?
drifterz do it slideways...
Tobie
Post
by Tobie » Tue Nov 10, 2009 8:06 pm
Tobie on Sat Jan 16, 2010 2:54 pm, edited 1 time in total.
smoothedgp
Posts: 2166 Joined: Thu Aug 14, 2008 7:21 pm
Real Name: F.J Steenberg
Post
by smoothedgp » Tue Dec 15, 2009 8:35 pm
ill take them if you still have them
Tobie
Post
by Tobie » Tue Dec 15, 2009 10:21 pm
PM'ed
Tobie on Sat Jan 16, 2010 2:53 pm, edited 1 time in total.
200sxrb25
Posts: 220 Joined: Tue Nov 10, 2009 9:39 pm
Post
by 200sxrb25 » Tue Dec 15, 2009 10:49 pm
Can i buy a set pistons and rod?
200sx rb25
lotus 7
