Page 1 of 6
Fueling Fundi's
Posted: Tue Oct 13, 2009 10:50 am
by Andrew.200SX
Hi , I need some assistance / advice.
'92 S13 CA18DET , standard, apart from 76 mm freeflow and aftermarket air filter.
The car was running fine , but has now started to feel like it is holding back when boosting. When cold , it's not so bad , more predominent when warm. At first I thought maybe it was fuel starvation , but after +- 5000 rpm , she pulls like a freight train. If I keep my foot flat from pull off , through the gears , she goes past the stagger in every low rev range and then runs. I am wondering if it isn't over-fuelling, and if so , why and where can I start fiddling ?
Thanks
Posted: Tue Oct 13, 2009 11:10 am
Check if you fuel pressure gos up when you rev her.
Posted: Tue Oct 13, 2009 11:35 am
With the info given....normally fuel pressure or fuel pump....test that and go from there.
Posted: Tue Oct 13, 2009 11:38 am
by cursed_s13
Also check youre spark plugs, and if you are losing spark...
I had a similar problem, with me the motor was loosing spark.
Posted: Tue Oct 13, 2009 11:47 am
My money is on feulpump.
Posted: Tue Oct 13, 2009 1:21 pm
by Andrew.200SX
Thanks guys. I also suspect fuel. I have re-serviced the car , replacing plugs , filters , etc for just in case.
How will I check the fuel pressure ? Fuel pump ?
Get a gauge of sorts ?
Posted: Tue Oct 13, 2009 1:24 pm
by poizen
Andrew.200SX wrote:Thanks guys. I also suspect fuel. I have re-serviced the car , replacing plugs , filters , etc for just in case.
not to sure if it is fuel pump cos i have the same problem when it cold cold i put foot flat and it feels like it wanna go backwards but then it all comes right and i have a walbro feul pump so i susspect the fpr as im going to replace mine soon
Posted: Tue Oct 13, 2009 1:28 pm
by Andrew.200SX
It feels as if the car is being held back and then as the revs climb , she takes off like a rocket !
Posted: Tue Oct 13, 2009 1:31 pm
by poizen
Andrew.200SX wrote:It feels as if the car is being held back and then as the revs climb , she takes off like a rocket !
just what i have so i know it not fuel pump as it new still not sparks as i tested coils and got new plugs i susspect the fpr so im going to change to a after market one i have no boost leaks and all systems have been checked i have not got any error codes and all ohms are spot on so im left with fpr
mayb someone else can direct us in a better direction
Posted: Tue Oct 13, 2009 1:40 pm
by Andrew.200SX
For what it's worth , I am going to clean up everything. If you have any joy with the FPR , then please let me know.
Posted: Tue Oct 13, 2009 2:49 pm
do you have a 8 port head. when i changed to that with my previous sx between 3000 and 4000 rpm it was like that.
Posted: Tue Oct 13, 2009 3:31 pm
by ReeceZ
buy a dictator, that will sort it out
Posted: Wed Oct 14, 2009 4:16 pm
by Lindt
stock regulator? check if it were bashed in to increase pressure, had the same problem on mine, some people think it'll make more power with higher pressure.
Posted: Thu Oct 15, 2009 7:32 am
Lindt wrote:stock regulator? check if it were bashed in to increase pressure, had the same problem on mine, some people think it'll make more power with higher pressure.
The car will make more power with higher pressure and I've seen this done and actually working but its not a good practice. Wanna increase your fuel pressure get a good pump and a decent adjustable FPR.
Posted: Thu Oct 15, 2009 7:43 am
by Andrew.200SX
I am still trying to find the problem , without going through the expensive process of elimination. I have also noticed that she is running fine up to .5 bar boost and then between .5 and .8 is when the holding back is there. I have a feeling it is fuel related. The 1 injector is also still leaking. I got another injector from Faheem and bought all 4 new insulaters and o-rings from Nissan , but 2 or 3 days later the 1 injector starts to leak again.
If money wasn't an issue , I would start with new injectors , fuel pump and management. Which by the way brings up another question.... Diktator or Nistune ?
