SMOKING
SMOKING
HALLO MENSE i need advice my sx smokes a bit when the turbo starts boosting. And when the car is idling and u rev her up to about 2 or 3 and a half thousend theres a knocking noise i dont know were it comes from and it smokes i have a suspision it may be the TURBO any advice PLEASE LET ME KNOW
RB 250 SX
i can't remember, but mine did the same and i thought OHOH here we go again... search the earlier posts for smoke - some bright spark here found a little restrictor washer in the one pipe - think it is the gearbox breather? I was sceptical as always, but I removed it and it worked shapshap!
try it, you'll like it
PCV Valve
http://200sx.za.net/phpBB2/viewtopic.ph ... e&start=15
i tried stopping the smoke by putting a potato in the zorst, but somehow that just gave me one of those spiral chips that tasted real kak
- ChemCool
200sx MP. Give Derek a call on this one. Just try and discuss with him. He is in Witbank on the moment. So if you want to call him on cellphone, you can get hold of his cell phone nr on our Nissan 200sx owners Club mobile application. Look under option 6.Phonebook. Dial with any cell phone *120*444*2000# to instantly access interactive information on our club.Myne has already been removed and stil smoking
Value added rates apply.
- Vlade
- * - Club Pimp - *
- Real Name: Barend
Smoke while idle = turbo seals
Smoke on boost = rings
Smoke let of boost = valve stem seals
that is how i would clarify it... and from my own experience... it may differ depending on condition of other items... if it rings you might also see more than usual amount of oil in the breather system.
WooHaa
- 0.6 Bar Boost
I would also look at turbo seals, but also look for oil leaks in & around turbo. I had a similiar problem until I found that oil was dripping onto the turbo from the oil feed.
Was strange, but once sorted it was cool.
The other thing that will cause the smoke is if the oil line into the sump starts blocking up. this causes the oil to stay on the turbo longer & force its way out the seals. Check the oil lines into the turbo, always good to do anyway.
Steer From the Rear !!
and the stem seals on the zorst vavles???
in my experience, three things were causing this on my engine (ca18det).
1. tired head - needed new valve stem seals and valve guides, there weren't so happy anymore! had the head cleaned, new bits put in and pressure tested by the engineers.
2. after 3000km's on the new rebuilt engine, i got similar symptoms, but smoke on idle too. when i started using plenty of oil and losing power, i pulled the motor again. the "new" oil rings were gone, but we found sidewall cracks in two of the pistons!!! replaced those with arias forged pistons - and havent had problems since (been about 10-11 thousand km's).
3. the smoking had now gone, but the turbo started making strange noises, and oil was dripping down the aluminium outlet pipe, from between the aluminium pipe and rubber hose. there wasn't really smoke, but i found major problems with the turbo. eventually replaced both wheels and shaft, and exhaust housing!
hope it helps!
hope it helps!
