vacuum manifolds
Posted: Wed Sep 16, 2009 2:29 pm
by poizen
hey guys im going to make vacuum manifolds like the ones in the pic
the inlet is a 6.5mm and the outlets are 4mm you can have any amount of ports as you desire
cost will be for polished 300 shiped anywhere in sa
Posted: Wed Sep 16, 2009 3:24 pm
by poizen
here a pic with all my lines connected
Posted: Wed Sep 16, 2009 4:07 pm
A bit off topic....I am looking for the "ports" what or where do you buy them......? IS it a bleed screw or what do you call it?
Posted: Wed Sep 16, 2009 5:46 pm
by poizen
Draco wrote:A bit off topic....I am looking for the "ports" what or where do you buy them......? IS it a bleed screw or what do you call it?
you talking about the brass fitting in the pic will they are called air hose nipples os swages what ever you prefer
Posted: Wed Sep 16, 2009 6:06 pm
i like nipples
Posted: Thu Sep 17, 2009 7:56 am
Cool thanks....was searching for those but did know the correct name so couldn't find any.....you buy it at air compressor part shops or hydrolic shops?
Posted: Thu Sep 17, 2009 8:03 am
by Speed breeder
Cool idea Mical...
i made one over the weekend, cos the t-piece under the turbo (positive pressure line to boost adjuster and waste gate) keeps melting...spares shops only sell plastic t-pieces for vacuum lines and at R14 a pop was getting expensive...
Posted: Thu Sep 17, 2009 8:06 am
Speedbreeder....most air supply shops sells brass or steel T pieces as well as hydrolics places....just for future ref. if hydrolic places dont have they make some for around R15
Posted: Thu Sep 17, 2009 8:07 am
by Speed breeder
Thanks D
Posted: Thu Sep 17, 2009 8:09 am
happy to help
