vacuum manifolds
Wanted or for sale
Locked
poizen
Real Name: Mical Mackay
vacuum manifolds
Post by poizen »
hey guys im going to make vacuum manifolds like the ones in the pic
the inlet is a 6.5mm and the outlets are 4mm you can have any amount of ports as you desire
cost will be for polished 300 shiped anywhere in sa
poizen
Post by poizen »
here a pic with all my lines connected
A bit off topic....I am looking for the "ports" what or where do you buy them......? IS it a bleed screw or what do you call it?
poizen
Post by poizen »
Draco wrote:A bit off topic....I am looking for the "ports" what or where do you buy them......? IS it a bleed screw or what do you call it?
you talking about the brass fitting in the pic will they are called air hose nipples os swages what ever you prefer
i like nipples :P
Cool thanks....was searching for those but did know the correct name so couldn't find any.....you buy it at air compressor part shops or hydrolic shops?
Speed breeder
0.7 Bar Boost
Post by Speed breeder »
Cool idea Mical...
i made one over the weekend, cos the t-piece under the turbo (positive pressure line to boost adjuster and waste gate) keeps melting...spares shops only sell plastic t-pieces for vacuum lines and at R14 a pop was getting expensive...
Speedbreeder....most air supply shops sells brass or steel T pieces as well as hydrolics places....just for future ref. if hydrolic places dont have they make some for around R15
Speed breeder
0.7 Bar Boost
Thanks D
:wink: happy to help
Locked
