200sx RB 25 CONVERSION
Hi Guys
Decided to buy a 200sx s13 end of the month. Want to go the rb25 route.
Is it alot of hassels doing that conversion. Anything i should know in advance?
- rat
- Real Name: Rat
hope you have a big budget cause anything rb is alot of $$$$ yes there is alot of work to do for it.
heres some more info and check under projects
http://200sx.za.net/phpBB2/viewtopic.php?t=4508
- ljS14
- Car: Evo
- Real Name: Shane
Agree with Rat 100%,This is not a convertion that you do half ass
,OR dont have a plan for
If you do it do it right and stick to your original goals unless you prepared to spend the money ,I started off wanting a 'stock' motor ,Ended up upgrading ALL the bolt-ons for power
Now im going built motor
Stock power is +-180wkw with the T28,Its not bad but be careful,The RB bug is killer,It will bite you for more power
Good luck,I sent my mail addy to you if you need anything,I forgot about a Hookup on the 3 Oct at RB25SX place,You must join as there will be some good info shared
1991 S13 200SX
1993 Z32 300ZX Convertable
Evo 8
Evo 8
