Sound in 200sx
Posted: Fri Aug 14, 2009 9:04 am
by 1slickcab-zn
I need to know what size speakers can fit into the front doors of a 200sx? 5.25" or 6"? will 6" fit?
Posted: Fri Aug 14, 2009 9:11 am
Stock is 4"x 6", but you can fit 5 1/4", 6.5" and 6" x 9" with a bit of modding.
Posted: Fri Aug 14, 2009 9:46 am
You can fit 5 1/4 in STD pods with small modding
Posted: Fri Aug 14, 2009 11:00 am
by 1slickcab-zn
Is the hole in the door big enough for a 6"?
Posted: Fri Aug 14, 2009 11:02 am
is the hole big enough for a 6 inch???
dude - are you sure you logged onto the correct forum?
Posted: Fri Aug 14, 2009 11:12 am
by 1slickcab-zn
All i want to know is can I put a 6" mid in the door with out having to cut the metal?
Posted: Fri Aug 14, 2009 11:24 am
Posted: Fri Aug 14, 2009 11:34 am
by 1slickcab-zn
Thanks man, I'm aware that I will need to make an MDF mount first, just wanted to know if there was enough space in the actual door.
Thanks
Posted: Sat Aug 15, 2009 10:45 pm
by POWDER
As per my own experience, as long as you keep it outside the door you are safe, If inside you wont have to cut metal but you might mess up your really difficult to find windows. The 4X6 brackets will need to be removed though either way. Everytime I open winds either terminals get ripped off or my door pannel pops off... Custom more fun anyway.
Re: Sound in 200sx
Posted: Mon Oct 31, 2011 8:05 pm
by fordsmith
Its depend on the player also that which type of player will be used in your car. Whether its a radio or CD player or DVD player. You can use rear deck speakers. They are 6 1/2's and for power purpose a 4 channel amp to power them. You can also buy complete set of speaker from ebay which costs $1200 which contains 2 speakers and other needed accessories.
Re: Sound in 200sx
Posted: Wed Feb 08, 2012 1:10 pm
by POWDER
Eish, $1200, thats a bit steep..... My Pioneer 6.5 inch and amp didnt even cost me R2000 ..... for $1200 u can do an entire settup from start to finnished.... With sub and custom pannels in doors
Re: Sound in 200sx
Posted: Wed Feb 08, 2012 1:25 pm
by NIZAN-R
fordsmith wrote:Its depend on the player also that which type of player will be used in your car. Whether its a radio or CD player or DVD player. You can use rear deck speakers. They are 6 1/2's and for power purpose a 4 channel amp to power them. You can also buy complete set of speaker from ebay which costs $1200 which contains 2 speakers and other needed accessories.
Kriekert Ban this damm SPAMER
Re: Sound in 200sx
Posted: Wed Feb 08, 2012 2:03 pm
by POWDER
Agreed, seems his just here to sell kak at exorbitant prices
Re:
Posted: Sat Feb 11, 2012 11:25 am
by BigKriss
", but yes the hole is big enough. "
and just how would you know that ??
Good original question though...Im busy with the same stuff at the mo......
Sound in 200sx
Posted: Sat Feb 11, 2012 11:52 am
by flash_vag
Certain 6" will fit. Stock spacer needs to be removed and custom mdf etc needs to be fabricated. If ur using at the minimum 6mm mdf , the speaker mounting depth shouldnt be more than 65/70mm. Also, countersink spacer to accommodate speaker as the stock 6x4 cutout on the door card will get in the way.
