Sound in 200sx
1slickcab-zn
Newbie
Sound in 200sx
Post by 1slickcab-zn »
I need to know what size speakers can fit into the front doors of a 200sx? 5.25" or 6"? will 6" fit?
Stock is 4"x 6", but you can fit 5 1/4", 6.5" and 6" x 9" with a bit of modding.
You can fit 5 1/4 in STD pods with small modding
1slickcab-zn
Newbie
Is the hole in the door big enough for a 6"?
is the hole big enough for a 6 inch???
dude - are you sure you logged onto the correct forum?
1slickcab-zn
Newbie
All i want to know is can I put a 6" mid in the door with out having to cut the metal?
veecee wrote:is the hole big enough for a 6 inch???
:D :D :D :D
You will need to make a mdf mount plate , but yes the hole is big enough. Ive got a template somewhere for it but you can just cut it the fit inside the door and then mount the speaker from outside.
1slickcab-zn
Newbie
:D :D :D :D
Thanks man, I'm aware that I will need to make an MDF mount first, just wanted to know if there was enough space in the actual door.
Thanks
POWDER
Real Name: Mike
Post by POWDER »
As per my own experience, as long as you keep it outside the door you are safe, If inside you wont have to cut metal but you might mess up your really difficult to find windows. The 4X6 brackets will need to be removed though either way. Everytime I open winds either terminals get ripped off or my door pannel pops off... Custom more fun anyway.
fordsmith
Newbie
Real Name: ford
Re: Sound in 200sx
Post by fordsmith »
Its depend on the player also that which type of player will be used in your car. Whether its a radio or CD player or DVD player. You can use rear deck speakers. They are 6 1/2's and for power purpose a 4 channel amp to power them. You can also buy complete set of speaker from ebay which costs $1200 which contains 2 speakers and other needed accessories.
POWDER
Real Name: Mike
Re: Sound in 200sx
Post by POWDER »
Eish, $1200, thats a bit steep..... My Pioneer 6.5 inch and amp didnt even cost me R2000 ..... for $1200 u can do an entire settup from start to finnished.... With sub and custom pannels in doors
NIZAN-R
Real Name: Renier
Re: Sound in 200sx
Post by NIZAN-R »
fordsmith wrote:Its depend on the player also that which type of player will be used in your car. Whether its a radio or CD player or DVD player. You can use rear deck speakers. They are 6 1/2's and for power purpose a 4 channel amp to power them. You can also buy complete set of speaker from ebay which costs $1200 which contains 2 speakers and other needed accessories.
Kriekert Ban this damm SPAMER
POWDER
Real Name: Mike
Re: Sound in 200sx
Post by POWDER »
Agreed, seems his just here to sell kak at exorbitant prices
Re:
:D :D :D :D
", but yes the hole is big enough. "
and just how would you know that ?? :D
Good original question though...Im busy with the same stuff at the mo......
flash_vag
Newbie
Real Name: Nash
Sound in 200sx
Post by flash_vag »
Certain 6" will fit. Stock spacer needs to be removed and custom mdf etc needs to be fabricated. If ur using at the minimum 6mm mdf , the speaker mounting depth shouldnt be more than 65/70mm. Also, countersink spacer to accommodate speaker as the stock 6x4 cutout on the door card will get in the way.
