LED bulbs
Posted: Fri Aug 07, 2009 7:52 am
Hi guys have LEDs
for reverse light and indicators
R130 for two.Only have two
https://forum.sxoc.co.za/
Well I built my own little lights for the indicators(side ones) ith about 6 LED's per light and they flash constant with the rest of the indicators. I had to however put a resistor or two in drop the voltage.Toby wrote:I have noticed on other cars that use the LED bulbs for indicators that:
1) It is barely visible under direct sunlight
2) It changes the rate at which the indicator flashes - it flashes quite abit faster
Just FYI.
Sorry to correct you, but the tempo is determined by the resistance.Charlvdw wrote:The tempo is determent by the wattage of the bulb, the lower the wattage the quicker it will flash seeing that you flasher unit is build for a certain wattage.
