boost controll
- poizen
- Real Name: Mical Mackay
boost controll
hey guys i bought a boost control from speed shop with the t piece that go between your turbo and actuator but with the bleed vaulve full closed im still getting 1bar boost wow feels great but i made one injector leak so i took it out and back to 0.6bar and injector not leaking but why does it go to 1bar mayb even more
surly it shoulndt do that
- poizen
yes it is i think it is that the t piece has a small hole in it where the ball sits to seal vacumGary57 wrote:Is that shitty T piece on the correct way??
but it takes over 1 bar to activate actuator
but the ca could handle 1bar was no splutter but i gone back to standard till i sort out it not going over 1 bar
please check this link, im also having problems with mine
also jumps to 1 bar, have to tap off to not go more
heres the install diagram.
i think those stickers on the t peice may be wrong side
http://www.nissanforums.com/z31-300zx-t ... ontrol.htm
- poizen
thanks donny i found that diagram the person i got the boost controll said it boosts to 1.5bar then returns to lets say 0.6 std
the prob is that the lil ball inside doesnt release itself at 5.5bar but at 0.1bar the reason why you getting 1.5bar is the design flaw i saw in it there is a lil hole where the ball sits so that the turbo cant suck a vacume from the vented line and the hole is like a 3mm id hole so you getting such restriction on the flow to the acutator
what i did it toss the t piece awy and join the main control barb to turbo and other to wastegate and instead of turnning to the direction of the - to lower boost it now increases boost so the controll is in reverse i hope this makes sense
- poizen
well im running the t25g i used to get boost cut at 0.7 but now i went to 1bar only getting boost cut at 1.1 bar good thing i stoped and saw the injector leaking so i turned it back to 0.65-0.7bar and it amazing it sticking there not soiking at 0.7 and coasting to 0.5 it sex on wheels really
