Dumpvalves
Dumpvalves
Hey guys I want my dumpvalve to give that chatter rather than the tttssssshhhhhhhhhh. What dump valve will do this?? Also I want the trumpet to be adjustable, I dont want this thing loud, it must be subtle.
that chattering noise you talk about i (along with the SXOC in the UK) call 'pigeoning' it's made by the sound of air going back over your tubbys impeller (kinda like talking into a fan
anyway - it's achieved by not letting the BOV dump as early as normal - you need an adjustable one.
my SSQV is like this. If you want the spring in (make it tighter - so need more boost to open it) then it will give you both noises...
however - after taking my old turbo off it had LOTS of play... which i blame on the pigeoning. So now i've wound it out, i barely look at the petrol pedal and it goes PSSSSHHH
chatter is usually heard from an internal wastegate!!!
when i changed to a cone filter, that sound became very prominent in my daily driving, but only because i still dont have a BOV installed.
i reckon once the BOV is in there, the wastegate chattering will be drowned out by the whooshing, cos i really dont like the whistling types, and i want a loud one!!!
edit = doesnt my post look the fool now!!!! thanks dislex!!!
edit = but it does explain very well the difference between the sounds when the cone is there vs the normal airbox!!!
- Vlade
- * - Club Pimp - *
- Real Name: Barend
Hehe yeah that sound was like a TSSSHHHHTRRRR BA BA BA.... The japs calls it the Bang Bang system... it was a way of Anti-Lag to keep the turbo from stalling...
http://www.rallycars.com/Cars/bangbang.html
Here is some you tube viewing pleasure...
http://www.youtube.com/watch?v=XaxhTnB-eos
Hennie Marais
Hennie Marais
