sleepy eye mod - the 1:15 youtube method
hey guys
here's an easy lazy eye mod - anyone gonna try it on their driftpig???
http://www.youtube.com/watch?v=PcaLnkI5 ... ed&search=
and yes - i'm enjoying youtube at the moment!
- Daniel
- Real Name: Daniël
LOL iv'e heard that happens. I tried it and it didnt work. Then decided to stop befor i break something...Ero_sennin wrote:I was bored one night and pressed the pop up light button really fast in and out and the lights started to alternate up and down was quite funny
not that anything could possibly break on a SX
ok - if i remember this correctly... here goes...
1. get in car armed with wire cutters
2. locate button that opens and closes lights without turning them on.
(its the top one on the right i think in our cars)
3. pry it out of its socket
4. have a close look at the wires behind the switch (should be about 6+-1)
5. locate the brown wire
6. cut it
7. put the switch/button back
8. turn on lights
9.press modified button in
10. turn off lights
11. press modified button twice quickly - like double clicking a mouse.
12. do it over and over to get desired height!!!
fact (for my sx at least) - if you follow steps from 7 onwards, that is without cutting the brown wire, the headlights will wink (go up and down) alternatively. first one side then the other. thats if you do the double clicking quickly!!!
6. cut it
8. turn on lights
10. turn off lights
makes me think back to my maroon sx - one day i was on the highway behind a bus full of chicks that were having a jol and waving and all, so my car waved back - but with the big button (not the flashing stick, coz that takes too long to go back down) my lights popped up, and then one went down but not the other and i felt like a real doos
had to drive home with lights up
is there a way to make the delay shorter when flashing?
- Toby
- Club Founder
- Real Name: Toby Kurien
If your lights "wink", then it's usually because the connector to the motor is a bit corroded. If you take out the connector, clean all the contacts, put in some grease and put it all back, should fix this. I know it fixed it on ChemCool's car.
