howzit guys
When I bought the car the previous owner who works for Nissan said that I must not steam wash or wash the engine 'cause it will damage the electrics in the car. He said I must just wipe it.....but this is a nightmare to do.....
Do you guys steam wash the engine or how do you clean it, and which parts must I watch out for, in order not to get water on them?
911 help
911 HELP - How to engine wash?
Checkout SA's ONLINE CAR MAGAZINE www.maxmyride.co.za , FOR THE CARS - THE GIRLZ - THE LIFE!
Also if you are looking for anything motor-related? checkout our AUTOMOTIVE ONLINE DIRECTORY
Hey bud
I feel your pain, I live on a plot with a nice dirt road leading to it, damn dust
Here are few links that may help:
<a href="http://www.automedia.com/Engine/Cleanin ... /1">Engine cleaning 1</a>
<a href="http://blog.lanescarproducts.com/2005/0 ... ml">Engine cleaning 2</a>
<a href="http://www.se-r.net/car_info/clean/deta ... ml">Engine cleaning 3</a>
Hopefully that helps you out a bit
- Bankie
Go and have a look at my engine bay before and after i cleaned it
http://200sx.za.net/phpBB2/viewtopic.php?t=323
All i used was a bottle of engine cleaner with a small paint brush. Throw the engine cleaner into a old cup or jar so that you can dip the brush into the engine cleaner. Then just brush off the dirt and afterwards you give it a nice hose down
Dont open the tap to wide just enough to wash away the engine cleaner.
The i use some silicone spray and spray all black parts with it to give it a shine
Ps - try and get a engine cleaner with a degreaser in it
Current - 200SX S14 96model
Ex - 200 Gxi Sabre - 124.6 kw & 208nm @ KSD 2006-07-29(with cams)
Clubsti - Unleash da beast
- ChemCool
I am owning my 3rd 200sx s13 since 1991. So I had them all, new and old. Water on the tappet cover: you run on 2 cylinders thereafter and find yourself opening the covers and removing sparkplugs. Exactly as some previous threads. So, I do any wash method as long as I am covering up the tappet covers. I normally do that with a towel. Then I shampoo, hosepipe galore and it works fine.
hhhhmmm...
i often run the engine without the coil cover on. often wash with the pressure washer, but i do remember once that the engine was running on only 3 after one of the washes!!!
it took some time before it steamed itself away.
or for a really good clean - you could follow the footsteps of Vlade, myself, toby, and i'm sure a few more, and just take the engine out, strip it down to single parts, send them to the engineers, clean the individual bits that haven't gone, and reassemble it when it gets back.
but thats not practical!!!
engine cleaner and brush works wonders, and its usually water soluble, so it will rinse away!
- Toby
- Club Founder
- Real Name: Toby Kurien
The reason I went to such lengths to clean my engine (yes that was my primary goal in getting my engine out!) was 'cos the car had leaked oil all over the engine bay (with previous owners) and the fan must've sprayed it around good and proper. Then years of heat had baked the greasy goodness right in.
Of course, you always need a good exuse to get your engine out, cleaning just ain't a good one. Luckily, my engine started making knocking sounds! You can always count on the CA18 to come through for you when you need some trouble
- Daniel
- Real Name: Daniël
Washing the engine is usually a nightmare for me too. So i have just left it as is of late
I usually have one or other problem after washing the engine, no matter how careful iv been. The only time I never had a problem is when i was visiting my folks and i used my dads compressor afterwards to dry everything.
