Dicktator help
LEON
Dicktator help
Post by LEON »
I need some help with the Dicktator management system.
Did somebody here have mappings for the ca18det?
Or some tips for mapping this system?
Dislex666
Post by Dislex666 »
ja i got a tip, sell it at get a REAL mgmt system :P
Toby
Club Founder
Real Name: Toby Kurien
Post by Toby »
Would South African mappings be optimal for use in Holland? How's the weather there? We go from -2 degrees celcius in winter to 35 degrees or more in summer.
LEON
Post by LEON »
Same here only the summer is not warmer than 28 celcius.
Its only to make the dyno time shorter.
Every engine is different so dyno is always helpfull.
In Holland there are only very expensive management systems you can buy.
I think the Dicktator is a very good system for his price.
Charl
Post by Charl »
yup I'm running dictator... I can give u my map. but I wouldn't use it on urs. u can maybe use it as a guideline to get urs set up.
I wouldn't mind looking at urs aswell?
which dicktator system are u runing?
200SX Catch my DRIFT?
Charl
Post by Charl »
LEON
Post by LEON »
I think we have the same setup.
Maby we can help each other?
LEON
Post by LEON »
I'm running the latest Dicktator with launch control
Charl
Post by Charl »
Ill email it to u quickly???
I honestly cant tell u which 1 im using. i think there is 2 in this country.:
dicktator m8 std and dicktator m8 60-2
ChemCool
Post by ChemCool »
Gremlin (George) is also using Diktator.
COOLER, FASTER, LIGHTER
LEON
Post by LEON »
The ca18det running the std version the 60-2 version doesn't work with the stock ignition system.
E-mail: INFO@LDM-TUNING.NL
