Page 1 of 3
Cone Filter???
Posted: Thu Jun 25, 2009 8:23 am
by KCSX
i put a cone filter on my car recently , this morning i took my car for a run to durbs , it was going great , after doing about 60km it started to feel slugish and didnt pull as strong as it did in the morning , could it be that the engin is sucking in to much hot air could that cause it , also when i put my foot down i think it back fired , what would cause this to happen???
Posted: Thu Jun 25, 2009 8:27 am
by poizen
where you from and what sx do you drive
Re: Cone Filter???
Posted: Thu Jun 25, 2009 8:30 am
by Drillergy
KCSX wrote:i put a cone filter on my car recently , this morning i took my car for a run to durbs , it was going great , after doing about 60km it started to feel slugish and didnt pull as strong as it did in the morning , could it be that the engin is sucking in to much hot air could that cause it , also when i put my foot down i think it back fired , what would cause this to happen???
I had the same problem.... I'll show you what I did to stop it from happening.
by KCSX
From Pietermaritzburg and its a S13 with the stock CA18DET
Re: Cone Filter???
Posted: Thu Jun 25, 2009 8:39 am
by poizen
Drillergy wrote:KCSX wrote:i put a cone filter on my car recently , this morning i took my car for a run to durbs , it was going great , after doing about 60km it started to feel slugish and didnt pull as strong as it did in the morning , could it be that the engin is sucking in to much hot air could that cause it , also when i put my foot down i think it back fired , what would cause this to happen???
yes please d like to see to
Posted: Thu Jun 25, 2009 8:40 am
by poizen
KCSX wrote:From Pietermaritzburg and its a S13 with the stock CA18DET
cool im glad to see kzn has more sx now so when you coming down to durbs again can meet up and help out
Re: Cone Filter???
Posted: Thu Jun 25, 2009 8:41 am
yes that does happen, try moving the cone as far forward as you can or a cold air intake
Posted: Thu Jun 25, 2009 8:47 am
by KCSX
well i work in durban , so im always around we should met up , i guess the more friends i have with SX's the better
Posted: Thu Jun 25, 2009 8:53 am
by KCSX
damn it cant seem to get the quote thing right
Posted: Thu Jun 25, 2009 8:56 am
by Drillergy
poizen wrote:KCSX wrote:From Pietermaritzburg and its a S13 with the stock CA18DET
Big day today, so Ill only post the mod around lunch tym.
Its mught look abit hillbilly
by phoenix s14
I think cone filters suck...
Posted: Thu Jun 25, 2009 9:02 am
by poizen
phoenix s14 wrote:I think cone filters suck...
alot of air bwaaah fail
yea man well where you work is your sx a daily driver
Posted: Thu Jun 25, 2009 9:06 am
by KCSX
i work in sherwood , its not a daily drive, i only use it on weekends , i just decided it needed a long run
Posted: Thu Jun 25, 2009 9:13 am
by poizen
KCSX wrote:i work in sherwood , its not a daily drive, i only use it on weekends , i just decided it needed a long run
well mine a daily driver i love it
i also got a cone and feel it slugish on a hot day goes beaqtuifull in the morning but hten engin bay heats up to 45-50 degrees or so gets tired im moving mine under the bumper today
i take it you have the stock intercooler
change that to a frount mounted intercooler look at my article page and see how to fit
then run another pipe from your air flow meter and go thru the opening where your old intercooler sat you need to cut bigger tho and then mount the cone there but please make sure you secure the cone well you dont want it falling off
Posted: Thu Jun 25, 2009 9:52 am
by Trance101
Ya, that sounds like heat soak. A FMIC does help and I'm sure a cold air intake would help aswell, but being a turbo engine they do generate alot of heat. Water/meth would probably work best to combat this.
