Cone Filter???
Cone Filter???
i put a cone filter on my car recently , this morning i took my car for a run to durbs , it was going great , after doing about 60km it started to feel slugish and didnt pull as strong as it did in the morning , could it be that the engin is sucking in to much hot air could that cause it , also when i put my foot down i think it back fired , what would cause this to happen???
- Drillergy
- Real Name: Darryl
Re: Cone Filter???
I had the same problem.... I'll show you what I did to stop it from happening.KCSX wrote:i put a cone filter on my car recently , this morning i took my car for a run to durbs , it was going great , after doing about 60km it started to feel slugish and didnt pull as strong as it did in the morning , could it be that the engin is sucking in to much hot air could that cause it , also when i put my foot down i think it back fired , what would cause this to happen???
- poizen
- Real Name: Mical Mackay
Re: Cone Filter???
yes please d like to see toDrillergy wrote:I had the same problem.... I'll show you what I did to stop it from happening.KCSX wrote:i put a cone filter on my car recently , this morning i took my car for a run to durbs , it was going great , after doing about 60km it started to feel slugish and didnt pull as strong as it did in the morning , could it be that the engin is sucking in to much hot air could that cause it , also when i put my foot down i think it back fired , what would cause this to happen???
- rat
- Real Name: Rat
Re: Cone Filter???
yes that does happen, try moving the cone as far forward as you can or a cold air intakeKCSX wrote:i put a cone filter on my car recently , this morning i took my car for a run to durbs , it was going great , after doing about 60km it started to feel slugish and didnt pull as strong as it did in the morning , could it be that the engin is sucking in to much hot air could that cause it , also when i put my foot down i think it back fired , what would cause this to happen???
- Drillergy
- Real Name: Darryl
Big day today, so Ill only post the mod around lunch tym.poizen wrote:cool im glad to see kzn has more sx now so when you coming down to durbs again can meet up and help outKCSX wrote:From Pietermaritzburg and its a S13 with the stock CA18DET
Its mught look abit hillbilly
- phoenix s14
- Real Name: Mark Appelgryn
- poizen
well mine a daily driver i love itKCSX wrote:i work in sherwood , its not a daily drive, i only use it on weekends , i just decided it needed a long run
i also got a cone and feel it slugish on a hot day goes beaqtuifull in the morning but hten engin bay heats up to 45-50 degrees or so gets tired im moving mine under the bumper today
i take it you have the stock intercooler
change that to a frount mounted intercooler look at my article page and see how to fit
then run another pipe from your air flow meter and go thru the opening where your old intercooler sat you need to cut bigger tho and then mount the cone there but please make sure you secure the cone well you dont want it falling off
