I am looking into Turbonetics turbochargers at the moment and would like to get some feedback from you guys. Whether it's first hand experience, reviews that you have read or just personal opinions please post and discuss the pros and cons.
Should I rather be looking at Garrett? If so, why?
Lastly please post up names and contact info for anyone able to put together a custom spec turbo(journal bearing) in JHB, preferably someone with a solid reputation
But if they aint got watercooling, then rather dont go for them. Watercolling gives u a much longer lasting turbo, and adds sum efficiency t the mix, since the turbo runs cooler!
Just find out before the time if the have watercooling.... my .2
I went through to Turbo and Nos Connection, really impressed with the level of service I received. I was quoted R6500 for a custom speced T3/T4 Turbonetics turbo which I don't feel is a bad price, however I'm not quite sold. I will definitely be buying forged pistons and conrods from them in the future however
My gut feeling tells me me to rather go with Garrett
ps. I am not looking for a direct bolt-on turbo so I'm not limited to the T25/T28 range.
I would like the turbo to spool at around 3000rpm, be pulling hard at around 4000rpm and only run out of puff at around 8000rpm or after if possible.
ok!!!!!!
I had a custom garret turbo on my rotary - it boosted like an animal at 3000rpm but faded quickly - I now have a GT4288 and this boosts late but goes right threw my range and I can rev 8 without stress on my rotary......... Fact is you can have one or the other! Rotaries flow much more than a piston and I struggled to fins the best combo!!!!
hehaeheahaeh! - fokken 6l-12l - better start saving for a MAHOOSIVE stroker kit
I reckon if you want big power you need to either get like a ma se T66 journal bearing turbo. Or a GT2871R - in .84 AR - should give you power round the 7k mark still - specially if you got lekker cams
