Running lean
Running lean
I have been wondering....can a car that starts running lean cause a slight increase of boost because of the velocity the gass is pushed out of the combustion chamber?
if not, why would boost increase without setting it, it might be actuator related, but if boost pushes the wastegate open because of a bad actuator spring boost will then decrease....not increase....am I right?
Running lean wont increase boost, running rich with very little timing will increase the spool up of the turbo and make the boost come in a few 100 rpm sooner.
If you are leaning the car out in load the boost can very well increase due to the increased efficency of the motor.
Becuase its leaner that doesnt mean the gasses flow faster...I have been wondering....can a car that starts running lean cause a slight increase of boost because of the velocity the gass is pushed out of the combustion chamber?
Hay Draco… Rising EGT's could add extra energy to the exhaust gasses decreasing spool-up time but I think we are talking engine killing glowing manifold lean here.
As Gary said a lot of guys dial out timing in the boost transition area’s and add fuel to get the mixture burning slower to lower lag by a few 100RPM but its normally drag cars as the tune makes the car lazy in those area’s of the map because of the decrease timing and plug fouling AFR’s..
Have you changed anything on the Z could there be a loose pipe? How are you controlling boost?
How can a increase in exhaust energy lower the spool up time??Rising EGT's could add extra energy to the exhaust gasses decreasing spool-up time
Spot on about the drag cars thing. I have done 2 cars which needed this, it also helps getting off the line...
? Did I use the wrong word? Pressure difference with higher EGT Exhaust Temps that’s why you wrap or ceramic coat manifolds. Higher temp gas want to expand by having higher EGTs there is more energy in the exhaust gasses making the pressure difference across the turbo more resulting in a lower spool up time maybe not much a few RPM.How can a increase in exhaust energy lower the spool up time??
When running rich with retarded timing you relying in the slower burning fuel to exit into the exhaust manifold and continue to expand creating the same pressure difference.
The more the difference to quicker the spool , it has it down sides but that’s no needed here
No quite sure where this pressure difference is but and increase in entropy is an increase the energy transfered to the turbine wheel. This increased energy transfer will cause the turbine wheel to generate more power. Basically an increase in exhaust gas will cause the turbine hweel to spool faster.
If you are talking about the pressure difference aross the turbine wheel then the difference the increased EGT will make is neglegible.
We add fuel and retard timing to put more energy into the exhaust. The mixture is still burning and therefore is transfering its energy into heat and work done on the turbine, instead of transfering it into work done by moving a piston down.
At the moment the boost is controlled by the actuator....which I suspect because even before I got it tuned I was unable to either increase or decrease the boost by normal means("tapping" air from line to actuator).Pinkfluffybunnys wrote:Hay Draco… Rising EGT's could add extra energy to the exhaust gasses decreasing spool-up time but I think we are talking engine killing glowing manifold lean here.
Before the tune it barely boosted 0.9 bar because of overfueling, after the tune it went up to a bar. As in the post about the Z I had fuel pressure problems, put in the pump and it was sorted, car stopped pinging, but did not tune yet. A week ago I put in fuel to take it for a drive and directly after I put in fuel it started pinging and boosted to 1.3 bar, checked fuel pressure but it was where I set it, I could see nothing funny.
After the fuel pump install I took it for a drive plenty times and had no problems and as I said, directly when I put in fuel that day I noticed the change, car aslo felt lazier than normal.
I have no doubt that I got bad fuel from the garage, but why would the car suddenly boost 1.3 bar?
Basically what I just said, now with added Vitamin B and C and Engineering lingo.but and increase in entropy is an increase the energy transfered to the turbine wheel. This increased energy transfer will cause the turbine wheel to generate more power. Basically an increase in exhaust gas will cause the turbine hweel to spool faster.
Have you check all the vacume lines already?
