SR20DET water pump
SR20DET water pump
Hey dudes... so I discovered my car keeps using coolant... and I noticed this damp patch on the paving in the garage...
Now this bothered me the past week... So tonite I did a bit of investigating, only to find that its my waterpump thats leaking. I searched a few forums and they say its something called a weeping hole... to tell you your water pump is f$##ed... Like just underneath the pump?? is this true??. Can I now say that my pump is Fooked?
if it is... then a long list of swear words will commence....
- phoenix s14
- Real Name: Mark Appelgryn
Start swearing them long words man... I had the problem with my Sentra 160 and with the 200sti and with my Primera... so yeah there is a hole on the bottom of the water pump and as soon as the seal goes it starts running out there...
Lesson I learned concerning keeping your cooling system optimal and not getting them cracked heads everyone keeps moaning about on Nissans...
Mix your anti-freeze with DISTILLED water. It does not contain minerals and hence does not form big rust deposits. usually only a thin light brown film and that is that...
Believe me it is worth spending the bucks... just make sure it is not "battery water" as this is acidic. has to be pure distilled water...
f#$k S#@t C#$t C#@K B#@%H MotherF#@#er ARGHH!!!!!!!!!!
dammit!!!
oh.. and its not just a few drops... its like a little stream... well... better that I see it now... otherwise it might've k@ked doing 120 on the N1 to Cape Town....
what will a new one set me back?
dammit!!!
- Drillergy
- Real Name: Darryl
phoenix s14 wrote:Start swearing them long words man... I had the problem with my Sentra 160 and with the 200sti and with my Primera... so yeah there is a hole on the bottom of the water pump and as soon as the seal goes it starts running out there...
Mix your anti-freeze with DISTILLED water. It does not contain minerals and hence does not form big rust deposits. usually only a thin light brown film and that is that...![]()
Distilled water is similar to De-Ionised water the process involes running the water through a filter system, then a reverse osmosis(RO) system and then deionizer. This will lower the conductivity of the water to a point where the water has very little minerals in them eg. Magnesium or Potassium.
Putting this in your vehicle is good, but bear in mind....
This water would absorb minerals faster then normal water, the water is so pure that if you wash you hands with it, you hands would get very dry cos it would absorb all the minerals and oils on your hands.
Same thing would happen in your car, so if you gonna use distilled water make sure you do a full water flush with distilled water a few times before using it and yes it is better that using normal water.
My 2c.
mmm cool thanx! will give you a shout If I get stuckDrillergy wrote:If you cant find it cheap, let me know. Ill source it for you in CT.
Pull up some of my old contacts.
