Basically im gona need some advice along they way from you guys
Im aiming for more Power this time
I bought Riaans incomplete project
These are all the parts we have so far
2Jz motor
R154 Box
Items marked with an * are brand new
*Toyota piston rings
*Toyota big end and main bearings
*Toyota complete gasket set (oil seals included) for engine
*Toyota electrical connectors for fuel injectors, coils, starter etc
*Toyota water pump and oil pump
*Toyota cam belt
*Toyota factory valve stem seals
*T72 turbo Mr Turbo
*S/S branch
*Tail 44mm waste gate
*HKS SSQ blow valve
*HKS 1.6mm steel head gasket
*600x300x76mm intercooler
*S/S boost pipes with silicone hose
*50mm aluminum radiator
*Toyota thermostat
E Boost 2 boost controller
K&N air filter
Toyota factory flywheel, clutch and pressure plate
76mm S/S exhaust
X Force tail box
LM1 air fuel ratio meter with oxygen sensor
Basially it gona be a build with factory parts,,,,,
Im going to use the stock pistons as they in good nik
hone the block and start fitting
upgrades planned, bearing in mind this is a budget build
RC injectors 1000cc.......
fuel rail
2 walbro pumps
oil cooler
dual fans
Water Meth Kit
Im keeping the black piping , it look really good in person
So here is a few pics, the engines internals are out, but its placed in
