2JZ GTE S13 swap will cost you this
Posted: Sun Apr 19, 2009 4:41 pm
Hi guys ive been readin that quite a few have been thinking about the cost of the mod,, so here is what it cost me
Im sure with a little shopping around you could find it cheaper, or find parts cheaper
The best thing about the 2jz is that you can order parts through toyota dealerships, just have the part no...
So here We go
2jz motor : R15 000
R154 Box 5 speed: R6000
Flywheel: R2000
Stainless steel Branch: R3100
Mr turbo T72 R5000
60mm Waistgate R1650
Greddy Cam belt : R1100
Prop Shaft Modification: R950
Make Engine mountings and set :R1500
Modify and fabricate hoses for Radiator: R650
Mr turbo Bigger Radiator R2400
2 x 12" fans : R800
Dicktator : R3400
2 x 3 channel coil ignitors: R1700
Walbro R1250
High pressure Fuel lines R650
New copper clutch R2500
76mm Full stainless exhaust with 1 silencer: R2600
Oil cooler R1800
600x300x72 Intercooler with piping R3000
HKs copy Dump valve R950
Silicone Rubbers R950
Boost controller R350
New Oil pump R1650
New Front main Seal R150
And make sure you do the oil pump mod before finishing up
And off course Labour and Bullshit from the tuner
If you lucky 5 months later you will have a car thats still incomplete
Is it worth it.......The one spin i got in it makes me think so
If you have a garage at home do as mush as you can your self:
So here We go
2jz motor : R15 000
Flywheel: R2000
Mr turbo T72 R5000
2 x 12" fans : R800
Dicktator : R3400
Walbro R1250
Oil cooler R1800
New Oil pump R1650
