Exhaust/Manifold Gasket Problem
Hey guys..
I have a really crazy problem..
I fitted a new exhaust system on to my s13 its the '63 size
Now ... since I've put it in I keep having my manifold gaskets burn in no time.. I mean really in no time..
about 2 weeks ago when one popped it blew hot air onto my electronics which melted + burnt the wires , ecu , ignition timer , 2 coil packs , and and and... the auto electric mac who i took it to sorted out all the electrics and fixed the exhaust gaskets .. R13000 later..
the gaskets are from nissan not cheap aftermarket stuff.
the exhaust is mounted with the same mount points of the original.
manifold has nothing wrong with it.. straight, no cracks, etc.
could the exhaust be to heavy causing it to pull the manifold down or could there be be too much back pressure when changing gears???
I'm totally lost and just wish for this problem to come right.. spent crap loads of trying to fix this and it keeps on coming back, taken it to plenty different people who all send the maniford to engineering and put new gaskets and it blows within a week or 2 again..
We Like Our Cars Like We Like Our Women: Clean, Stripped, and 17 Years Old.
- poizen
- Real Name: Mical Mackay
i have the same problem my two back keep leaking im busy having copper gaskets made up ill sell you a pair if you like pm if interested they should seal nice plus they work harden so will be good combo also what nuts do you have on are they the right copper lock nuts else they will undo themselves and cause the mani to leak
when will you have them + price?poizen wrote:i have the same problem my two back keep leaking im busy having copper gaskets made up ill sell you a pair if you like pm if interested they should seal nice plus they work harden so will be good combo also what nuts do you have on are they the right copper lock nuts else they will undo themselves and cause the mani to leak
- poizen
i should have this week not sure on price i just told them to make ill do a price when recieve themm.i.g wrote:when will you have them + price?poizen wrote:i have the same problem my two back keep leaking im busy having copper gaskets made up ill sell you a pair if you like pm if interested they should seal nice plus they work harden so will be good combo also what nuts do you have on are they the right copper lock nuts else they will undo themselves and cause the mani to leak
Copper is not a bad idea but I recommend that you use stainless steel, myself and a few others used that, worked great, I used mine with normal celicone and never had a problem.
Also, if you skimmed your manifold it might mean that your surface against the head is not what it should be....of course that is only my mind asking a question....if it's not the manifold surface or the exhaust thats blocked it must be the head exhaust outlet surface....you might get the gasgets and sit with the same problem....
hope you get it sorted!
