guys im sick of these indivd coils is i know i can get it converted to leads but can i do it with the std managment or not thanks
if yes who in durban would do it
time for a coil change
- poizen
- Real Name: Mical Mackay
It can be done. But there are ups and downs
The Up
I think they use 4 x GM single coils they have the same set-up as the stock coils, Power, Signal, Earth then build a plate to house the coils and use leads to get to the spark plugs.
the just splice the stock Coil harness to the new GM stuff plus the Gm coils are very cheap.
I think they use 4 x GM single coils they have the same set-up as the stock coils, Power, Signal, and Earth then build a plate to house the coils and use leads to get to the spark plugs.
They just splice the stock Coil harness to the new GM stuff plus the Gm coils are very cheap.
The Bad
The coils are very weak seeing break down at low boost levels when compared to a good stock example. I have seen a few guys use MSD blaster SS coils on the stock system but the dwell time needs to be changed
The Up
The Bad
