Know Your SR20DET
1991-1993 202 hp@6000 rpm Garrett T25, 0.64A/R Exhaust, High-port head, 370cc/min injectors Red valve cover
S13 Silvia & 180SX 203 lb-ft@4000rpm 0.80A/R Compressor
1994-1998 S13 180SX 202 hp@6000 rpm Garrett T25, 0.64A/R Exhaust High-port head, 370cc/min injectors Black valve cover, flat on top
203 lb-ft@4000 rpm 0.80A/R Compressor
1994-1998 S14 Silvia 217 hp@6000 rpm Garrett T28, ball bearing 0.64A/R Low-port head, VTC variable intake Black valve cover with a hump
203 lb-ft@4800 rpm Exhaust 0.60A/R T04B Compressor cam timing 370cc/min injectors that peaks at cylinder No. 3
1999-2001 S15 Silvia 247 hp@6400 rpm Garrett T28 ball bearing, 0.64A/R Low-port head, VTC variable intake Black valve cover with a hump
(manual trans only) 202 lb-ft@4800 rpm Exhaust, 0.60A/R T04B Compressor cam timing, 444cc/min injectors, better materials in turbo and better wastegate flow design that peaks at cylinder No. 3
Know Your SR20DET
- n1smo200sx
- 0.5 Bar Boost
Know Your SR20DET
