4000 rpm
4000 rpm
Hi all
I replaced head gasket. Now the car pulls ok up to 4000rpm but then it gets sluggish. The turbo spools up quick enought tho. Any ideas?
Fuel pump.
Thats what i thought but it worked before and car only stood for a week.
Fuel filter... kak petrol...
Thanx ill check the filter. Kak petrol = sa. :D
NIZAN-R
Real Name: Renier
Tj
Post by NIZAN-R »
Ive got the same problem it feels like a flat spot until about 4800+- wil change filter tomorow and test it
antman
Engine: VG
Real Name: Tony
Post by antman »
Check if the vacuum pipes are connected as fuel pressure rises when in boost and if the fuel pressure reg pipe is off pressure will be low........can also be fuel pump but as you had the head off you might have forgotten to put back a vac pipe or two.
Problem sorted, X-cam one tooth out. Thanx Vaughn!
NIZAN-R
Real Name: Renier
Jta
Post by NIZAN-R »
Changed the feul filter it was blocked cant blow thru it and when you blow in reverse it looks like mud pissing out
Wil give it a test 2 morrow
