For the Z fans. This is my Z and the work done thus far as posted in other forums(didnt type this shyte out just now):
Continue............
- Seats done in black leather with red roman stiching and perforated center
- Underdrive pulley kit - (10HP Gain Expected)
- Front and Rear strut bars
- PreCat and DeCat removal
- Recirc Valve Remove - Dump Valves Installed
- EGR(Exhaust Gas Recirc) eliminated
- AIV eliminated
- White Clear Fender Indicators Installed - (Extra 20HP, came off a Type R Honda)
What is currently being done as I type.
- GT28 Turbo upgrade
- Stage 3 Clutch updrade - Copper Ceramic
- Lighter Flywheel - approx half stock - (10-15HP free across range)
- Electric Fan Conversion (3000cfm) - Removal of Clutch - 15HP gain expected
- Twin Stillen Intercooler Upgrade - 70% better airflow - Complement added Boost
- Jim Wolf Technology ECU Upgrade
Still to Come
NISMO 555 cc Injectors
x3 Thickness Radiator - looking around for custom job
1 pc DriveShaft - half the weight of stock
Z Emulator Hardware - Custom Tuning
Target on 1.2bar boost = 330kw - 450HP Hopefully
Short Gear Shifter installed, expected to reduce gear shifts by up 40%, similar to this one
Just some help for those quick DSG shifts.
Continue..........
Heres how it was done..had some custom brackets made and installed 330mm Brembo discs ...calipers now sit less than 1mm away from the 19inch mags..?hope the wheel bearings dont go!!!
Continue.........
A shit load more has been done and some more to come when I get more time and I feel like getting my hands dirty. Right now shes is just purring..so why touch it.
