White smoke..!
White smoke..!
Hey guys,any idea y wn i rev my sr20det it blows white smoke from the xhaust?also what i need to do to get it fixd?plz help..tnx
- Slide 'em Wide
- 0.6 Bar Boost
There are a number of potential possible problems that may cause this. First do a compression test. To see if your rings/ bores are still ok. (this is the most expensive to fix) The second is that the turbo could be having a oil seal thats bust. I believe that MR.Turbo do recons on the turbo.
The other possibility is that the white smoke appears when the car is sideways and you are fairly hard on the gas. I which case watch for rear tyre wear.
What Id rather be dooing!
- Speed breeder
- 0.7 Bar Boost
If you get the kit, you can do the recon at home...
One of the SNS issues have a step by step guide on how to rebuild a turbo... half and hour job after the turbo has been removed from the car.
I redid my T3/T4 (cost R195) and seems to still do the trick...
I am sure the T28 will be more expensive for the kit...
Some people I am sure will say you need to balance everything again, which I am not convinced about, unless your shaft (turbo shaft) has uneven wear and this was causing the seals to fail in the first place...
I think we have to start developing a troubleshooting sheet with these type of issue on them and have the responses, answers and suggestions on them, as we keep getting the same queries
- and quite rightfully so... if someone is new they don't have the history of the past posts...
