If you made your SX N/A what engine would you swop in
Just a Thought that crossed my mind
when i was thinking i need a light on fuel reliable car
So here the senario you have a complete s13 with no engine and gearbox
But if you were on a budget what would you do
must be N/A .....not turbo engines
1st option must be a 4 cyclinder readily available
2nd option must be 6 cylinder readily available
3rd option must be a 8 cylinder readily available
let see what you come up with
oh and it doesnt have to be nissan engines
- ReeceZ
Eish donny, tuff one,
4 cylinder - Group A TRD 20V engine (same as in Initial D)
6 cylinder - the 3.2 lump from a Honda NSX
8 cylinder - either the corvette LS1 or a 672 Hemi
editted again, i couldn't read properly today
if fuel economy is your MAIN consideration..
4cyl - bmw or volkswagen turbo diesel.. i know my 320d gives between 16 to 22 km/litre, this in a 1.5 ton car..
6cyl - bmw or volkswagen 3l turbo diesel, these have stump pulling torque, try racing one on the move
the latest version of these 3litre/6cyl/twin turbo diesels puts out 200kw/600 odd nm torque
and they are not much heavier than the 4cyl on juice..
8cyl - difficult.. but needless to say, you will get better consumption with a modern japanese v8 than a american lump.. ive heard the lexus v8 is not to bad on juice if tuned properly..
my 2 cents..
my 2 cents..
300zx fairlady 1991
200sx s13 with vg30det @ 1bar
- phoenix s14
- Real Name: Mark Appelgryn
mmmmmmm let's see...
4Cyl - SR20 NEO VVL - Nissan's Vtec motor... and make it do 12000RPM...
6Cyl - VQ35 - just sounds so sweet...
8Cyl - VK56DE - go big or go home... The VK56DE employs a massive 98mm bore and 92mm stroke for a total displacement of 5552cc. This engine makes 315 bhp (234kW) at a low 4900 rpm and more than 500Nm of torque at 3600 rpm. The BEAST will rip anything to shreds including your 19's
The VK56DE you just import from the US...
It has to be Nissan... I don't like mixing manufacturers...
- n1smo200sx
- 0.5 Bar Boost
