Bearing Knock SR20
Posted: Mon Dec 29, 2008 5:45 pm
OK so it's official... The SR is very sick and needs a tripple bypass. It is definately a rod knock on one of the cylinders.
Gonna see if I can take as many pics as possible while I rebuild the motor like new.
Parts list:
- new main and big end bearings.
- new smallend bushes.
- crank cut.
- 0.5 oversize pistons and rings.
- greddy head gasket/STD depending on funds.
- new oil pump.
- block and head acid washed and squeeky clean including oil squirters
- guides checked and replaced where needed.
- all seals and gaskets replaced.
Already new items:
- timing chain, guides and tensioner.
- lifters
Hop-ups:
- cylinderhead gasflow
- all parts balanced.
- complete motor balance.
- new exhaust.
- turbo relocation to clear dipstick.
- flange added to manifold for external wastegate. (to be done later)
- a whole range of sensors fitted for engine monitoring. (also been lying for about 2 months)
Hopefully I win the lotto and I can buy a complete JUN SR20DET motor.
Parts list:
- crank cut.
- new oil pump.
Already new items:
- lifters
Hop-ups:
- new exhaust.
