Humidity and Horsepower readings
ChemCool
Post by ChemCool »
I ask. Can a HUMIDITY % difference of 35 % be culprit to a variation in a horsepower reading from let say typicall 103 kw down to 88 Kw? The high Kw reading during the low humidity(45% during cool evening) and 88 Kw reading during high humidity(70% and evening rain) ? Johansx, has you ever experienced this type of results with your electronic gadget bought from Autostyle?
COOLER, FASTER, LIGHTER
The Calibrator
Post by The Calibrator »
Water doesnt burn and displacees air in the atmospere therefore the higher the humidity the lower the power.
Unless your engine is knock sesitive when the high humidity can act almost like water injection.
What was wrong with the dyno's weather station didnt the operator input the atmospheric conditions so that the figures were corrected?
Toby
Club Founder
Real Name: Toby Kurien
Post by Toby »
Could make a difference, dunno if it's thatmuch tho. Did you get your G-tech??? :) :)
johansx
Post by johansx »
Once my car is fixed, I will concentrate in calibrating the G-memter. Now it is only a toy to see what G's I can get trough corners... scary stuff :wink:
widowmaker
Real Name: Walter
Post by widowmaker »
calibrator, you got a dyno?
The Calibrator
not on my premises but I have 2 to choose from.
widowmaker
Real Name: Walter
SPECIAL GROUP PRICE ON DYNO DAY!!!
