spiking and loss of power
Dunn
Real Name: Ryan
Post by Dunn »
This is really strange,if i am at about 3000 before car reaches optimal boost,say it's at 0.1 and rissing if i give it stick the car spikes to about 0.9/ 1bar then returns to 0.6/0.7 bar ,sumtimes it sort of lags as well,by this i mean the gauge shows boost coming though but the car feels as if it's gone then comes back then it's gone and then it comes back.
here is the tricky part,if i ease it into boost and only give it full throttle once the car is at full boost then none of these problems occur.although sumtimes i get the boost dissapearing thing
please help,any ideas or am i just not driving the car correctly as it is my first turbo cab
ex Accord Type S
ex Impreza STI ver 6
ex 97 Civic Vtec
ex 99 conquest 20v
ex Conquest RSI
Post by Vlade »
I had this cleaned my MAF and it sorted it out
Dunn
Real Name: Ryan
Post by Dunn »
thanx Vlade i'll try it tonight and check it out
ex Accord Type S
ex 97 Civic Vtec
ex 99 conquest 20v
ex Conquest RSI
WooHaa
0.6 Bar Boost
Post by WooHaa »
I had this once with my first SX.
The only thing that finally sorted it out was changing the spark plug to a hot plug.
Steer From the Rear !!
Post by Vlade »
If that doesn't work, try check for any boost leaks, if there arn't any check your ECU, it might be that there a wire is loose or something...
Things to check
* two wire water temp
* knock sensor
if any of those are disconnected your ECU will switch to the high octane map, and it causes an unpleasant ride
