Oil Leak Chassis Back of 200sx s13
ChemCool
Post by ChemCool »
VC or any other member, what on earth is going on here? I have just stopped oil leaks front of sx, now this one rocks up back underneath. What is the issue here? Easy difficult etc? What must I do?
Chem :shock:
Chem :evil:
COOLER, FASTER, LIGHTER
ChemCool
Post by ChemCool »
that bottle of GTX in the boot fell over???
Guy
Post by Guy »
Looks like a fluid filled bush that has split.
ChemCool
Post by ChemCool »
Guy wrote:Looks like a fluid filled bush that has split.
Ok, got it. It just was never knowledge to me you get bushes with oil in. Thanks.
Chem 8)
well - i didnt mention that because i didnt know that the bushes in the rear subframe were filled with fluid, but since the engine mounts, and the caster arm bushes in front are filled with fluid - it doesn't surprise me really!
whats going to surprise you chem is that you will probably really struggle to get those bushes... so maybe search for vlades drawing on the solid bushes, and get number 2 to make them for you!???!
ChemCool
Post by ChemCool »
veecee wrote:well - i didnt mention that because i didnt know that the bushes in the rear subframe were filled with fluid, but since the engine mounts, and the caster arm bushes in front are filled with fluid - it doesn't surprise me really!
As I said me neither, about fluid in those bushes! VC you are becoming sharp regarding number two. :D
Chem 8)
