Idle Control Valve - SR20DET
Wanted or for sale
Locked
Hey guys. Anyone got one of these?
do you really need it, you can use the car without it
rat wrote:do you really need it, you can use the car without it
serious?
doesn't the car have difficulty to idle then?
will be bad on the cold start but when it warms up it will be fine, if i am right
mmm ok... so... help?
uhm... link not working... but i shall use the almighty search function! hehe
RB25SX
Post by RB25SX »
I should have one, if I can find it. You can have it.
RB25SX wrote:I should have one, if I can find it. You can have it.
AWESOME!! thanx man!
ChemCool
Post by ChemCool »
rat wrote:http://tobykurien.com/phpBB2/viewtopic.php?t=2041
is it the same as this?
Yes it is. It is called VC's style and it works brilliant with my sx . It is also called dustbin stuff!! hehehehehe... lol
Chem 8)
COOLER, FASTER, LIGHTER
Chem 8)
and whats your experience with it chem? cause it you and VC say it works I;m gonna take it off tonite.
ChemCool
Post by ChemCool »
Chem 8)
So now I am controlling the idle manually with the butterfly. Initially it took me some time to set the idle, but once the injector leaks rectified the sx idles perfect. If you set it with the butterfly only (you know like NA, I think?) you set the idle where y want it. With cold start I sometimes need to slightly assist with fuel throttle (like a quick soft whamm, whamm :lol:)
and it then idles low initially and once warmed up very stable on where you intended the sx to idle. Mine is set 900 rpm's and it drop to about 750/800 once aircon is switched on and while idling. Same scenario with h/lights on.
Chem 8)
mmmm.... ok you just sold it! I;m gonna strip it of now. and make a blank off plate.
yeah! more weight saving! hehe
Thanx Oom! :D
and me :lol:
rat wrote:and me :lol:
Yes thank you to Ratman!
Locked
