Posts: 9505 Joined: Tue Jul 31, 2007 11:51 pm
Post
by Riekert » Wed Nov 12, 2008 5:21 pm
Hey Sokar...
Quick Q.
The EGR on the SR20...
is this also part of it?
the pipe from the exhaust mani to the intake? do I need that pipe? cause mine was uhm well cut in two....
Riekert on Mon Nov 17, 2008 3:18 pm, edited 1 time in total.
Enzio wrote: Who needs ligths? When you're going sideways forward facing lights don't do anything but confuse squirrels and sheep next to the road...
Sokar
1.0 Bar Boost
Posts: 1055 Joined: Wed Nov 08, 2006 9:30 am
Post
by Sokar » Wed Nov 12, 2008 6:45 pm
Yip,
The EGR is a system that bleeds air into the exhaust to help the cat IIRC. Even though South African S14's didnt have Cats AFAIK.
So you remove that pipe and the 2 bits that look like they belong on a geyser in the roof of your home. This will leave a hole in you exhaust manifold, and a hole in your intake and a homeless vacuum line, the exhaust side can be blocked with an appropriate bolt, the intake side needs a nice piece of metal cut to the rough shape and bolted to the intake with some gasket maker to stop air from leaking out, commonly referred to as a blank-off plate, the homeless vacuum line can be blocked off.
Captain Slow to the rescue!
Post
by Riekert » Wed Nov 12, 2008 7:40 pm
Awesome thanx!!! that make life just THAT much easier! thanx man! gonna do it tonite!
Post
by Riekert » Wed Nov 12, 2008 11:49 pm
So I took everything off....
quite a lot of stuff... will take pics of the blackoff plate and rest of stuff later....
Post
by Riekert » Thu Nov 13, 2008 2:05 pm
Hey... not EGR related but...
it seems like I'm missing something here:
doesn't it normally have a little pluggy there?
Sokar
1.0 Bar Boost
Post
by Sokar » Thu Nov 13, 2008 2:09 pm
It should, that part of the idle control
STIG
Posts: 131 Joined: Fri Sep 26, 2008 8:21 am
Post
by STIG » Thu Nov 13, 2008 2:21 pm
Your guys paintbrush skills are impressive.
Post
by Riekert » Thu Nov 13, 2008 2:23 pm
Shit... mines missing...
uhm how much for a newish one? Looks like ferolli might've broke it off.... or pulled it out.
Post
by Riekert » Thu Nov 13, 2008 2:24 pm
STIG wrote: Your guys paintbrush skills are impressive.
hehe thanx... I don't have photoshop at work... plus it's easier just to edit it in photobucket...
STIG
Post
by STIG » Thu Nov 13, 2008 2:25 pm
Paintbrush kicks any Photoshop's ass....
Post
by Riekert » Thu Nov 13, 2008 2:37 pm
hehe nice.
Ok... uhm what can I do to fix it? will one of a SR'd primera work? saw doc G had one???
Posts: 5378 Joined: Sat Jun 30, 2007 10:38 am
Post
by rat » Thu Nov 13, 2008 2:46 pm
omg stig can use paint
Post
by Riekert » Mon Nov 17, 2008 3:21 pm
Ok so I blocked the idle control valve....
Now... I know I can use the S13's power transistor and the Wastegate control... now does the S13 have a boost pressure sensor?
Sokar
1.0 Bar Boost
Post
by Sokar » Mon Nov 17, 2008 3:24 pm
Riekert wrote: now does the S13 have a boost pressure sensor?
Nope, not that I know of.
Post
by Riekert » Mon Nov 17, 2008 3:26 pm
Sokar wrote: Riekert wrote: now does the S13 have a boost pressure sensor?
mmm... ok... And I will need that won't I?
