timing keeps changing plz help
- poizen
- Real Name: Mical Mackay
hey guys i have a problem when i tighten the 3 bolts on the cas the timing keeps changing what will cause this pls help *plus i do hold the cas tight in place*
OK do this, take a black marker and a ruler, draw a line on the CAS so that you have a nice black mark!
Then turn the cas a few degrees off so that when you tighten the nuts that it pulls it on the timing that you want it!
None of the guys running CA here will have a CAS sitting on the same place as you. Your timing is set according to your mods and boost and fueling and and and and a lot of other things!poizen wrote:not that im doing it wrong it never did this befor but these bolts stuffin me around
also guys with ca running 15-16 degree where do the bolts sit in the slot are they near the middle or more to the edge
- poizen
HancoB wrote:Dude, start thinking now!poizen wrote:not that im doing it wrong it never did this befor but these bolts stuffin me around
Thats why I said, either take it to dyno or get someone who knows what he is doing to tune it!
um 15 degree is standard and i have done the marker trick
poizen wrote:HancoB wrote:Dude, start thinking now!poizen wrote:not that im doing it wrong it never did this befor but these bolts stuffin me around
uhm then get it to 15.
- poizen
i do get it but also we got to be realistic im running std timing so anyone who as std timing which is 15degree then can they help
also im not spending 400-500 for a guy to tighten 3 bolts when take it to be dyno there nuffing wrong with the way im dong it all i want to know is what would the most likely cause of this timing changing by tighten the bolts does anyone else have this problem
You tighten them clock wise...right...so when you tighten them, it will move to the right a bit, same as to the left when you loosen the nuts.
Then if the black marker trick doesn't work do this...tighten them so that it doesn't move, then you take a light hammer and a blunt steel rod or something and then nip it with the hammer so that it goes to where you want it and then tighten them!
Your 100% correct, set it to 15 degree's, that is your base timing, dont listen to ANYONE that tells you to set it on a dyno, It is one of the most getto things in the book to set your base timing to any form of mods or shit, wtf are you people on? Base timing controls more than just ignition timing, it also controls fueling, idle actuation ectr ectr, everything runs off that, no matter WHAT you have done you should always run 15deg base on your stock ECU, if you cant get the results you want go get a piggy back or a stand alone.poizen wrote:i do get it but also we got to be realistic im running std timing so anyone who as std timing which is 15degree then can they help
Poizen, get out your FSM read how it tells you how to disconect the TPS ectr to do it, make sure the rubber o-ring isnt pinched get it to 15deg and slowly tighten one by one till its tight, if it moves there is somthing in the CAS drive or mounting bracket loose,,, and for shit sakes dont hit the fckn thing with a hammer or blunt object!!!! those things are DAMM sensitive and pop that sensor and your in for a LOVERLY replacement price.
If your car is set up right (cam timing) 15deg should be almost spot on in the middle on the slots, if the head and block has been skimmed it will obviously change slightly.
To those of you that arnt the smarter, if you advance the CAS your car will more than likely detonate due to our crap fuel ESPECIALY if you have added boost... If you retard the CAS you will loose power through out the whole map, your fuel consumption will go to shit and the only part that will benefit is a TINY little bit up top ONLY if you have added boost, even then your injection timing is off,,, hurting 95% of the map for 5% is just stupid.
- poizen
RAW wrote:Your 100% correct, set it to 15 degree's, that is your base timing, dont listen to ANYONE that tells you to set it on a dyno, It is one of the most getto things in the book to set your base timing to any form of mods or shit, wtf are you people on? Base timing controls more than just ignition timing, it also controls fueling, idle actuation ectr ectr, everything runs off that, no matter WHAT you have done you should always run 15deg base on your stock ECU, if you cant get the results you want go get a piggy back or a stand alone.poizen wrote:i do get it but also we got to be realistic im running std timing so anyone who as std timing which is 15degree then can they help
thanks raw glad you agree with me ill take the mounting plate off it myt be loose will see tomorrow
Thats funny, coz I have seen plenty other tuners do that. And they do it on the dyno, measuring your exhaust gasses and running diagnostic software with that.RAW wrote:Your 100% correct, set it to 15 degree's, that is your base timing, dont listen to ANYONE that tells you to set it on a dyno, It is one of the most getto things in the book to set your base timing to any form of mods or shit, wtf are you people on? Base timing controls more than just ignition timing, it also controls fueling, idle actuation ectr ectr, everything runs off that, no matter WHAT you have done you should always run 15deg base on your stock ECU, if you cant get the results you want go get a piggy back or a stand alone.poizen wrote:i do get it but also we got to be realistic im running std timing so anyone who as std timing which is 15degree then can they help
and as for the hammer part, a small, light weight hammer with light taps or nips wont do anything. Driving on the SA roads does more damage to it than lightly tapping it with a hammer.
I guess turning the fueling screw should be done by electro microscopic hydraulic arms then not to damage it?
or would a plain screw driver work?
