what is this
- poizen
- Real Name: Mical Mackay
what is this
hey guys what is the like acuator thingy next to the stock fpr and what does it do cant find in service manual thanks guys
- poizen
thanks explains alotDraco wrote:http://www.nicoclub.com/articles.php?id=225389
but why is it not in my service manual is cause service manual is for a 4 port
sorry guys not to cluded up with 4-8port diff
Well it is one of those topics where you have alot of different opinions, there has been "tests" done by some forum guys somewhere that claims the 4 port flows better and therefore could give more power.....
Aperently the 8 port has better low down torque....
As for drifting use.....more torque down low helps loose traction so it is ok, but in my experience, if there is any delay or problem with the system it delauys your power sticking your nose in the ground and then pulls, this only happens when you change gears.....
My opinion, disconnect it or put on a 4 port head....
The only answer that I can think of is that the japspec manual is not availible on the net where most get theirs.....poizen wrote:thanks explains alotDraco wrote:http://www.nicoclub.com/articles.php?id=225389
Again if you search you will find the answers you want.
Connect a vacuum line to it, it will give you more low down torque. Unfortunately the 8 port head wont flow as much as the 4 port.
All this means is you have an import engine in your car...
- poizen
draco dont worrie it all the same ive had the car cor and relicenced so all info is correct and nubers are same on my licence
gary it has a vacume line on it already there nuthing wrong with it just was wondering what it myt be and i would search if i knew what it was
how mus i search sumthing dont know what it is type funny thing at back of ca18det motor in google
that why i ask here for trusty info
thanks for the help guys
