Look at this sweat deal (at least I think it sweet). I have come across and tell me what you think and what could be missing , I'm tempted I wont lie.
RB20DET (import Motor,not sure of condition) - R 5000
RB20DET ECU - R1600
RB20DET Wiring Harness - Uncut complete and I mean Complete - R3500
R32 RB20DET Engine Crossmember and Gearbox mount- R 2200
Nistune - R 2600
Total 15600
OK I know this works out to R15600 very expensive but this should be a straight drop in except for the drive shaft and I'm sure the CA18DET gearbox does fit (might be wrong here)
I need the nistune to get my 300ZX airflow meter to work.
its a pipe dream but I thought I would share, I mean I spent almost R13000 on my CA Rebuild but it was a complete forged rebuild
I also Looked into refreshing the RB20DET before it goes in:
(Tell me if I missed anything)
Nissan RB N1 Water Pump - R2000 (imported)
Nissan RB OEM Timing Belt - R800
Upgraded RB Crank Collar - R1000 (A Must for any older RB)
Nissan RB N1 Oil Pump - R2700 (Imported)
Nismo RB Thermostat - R800
Total - R 7300
Then I looked at rebuilding the RB20DET.
Doesn't include engineering ....
Nissan RB20DET OEM Gasket Kit - R2700 (imported)
Turbo recon - R2000 (local)
ARP RB20 Rod Bolt Kit - R900
ARP RB20 / RB25 Head Stud Kit - R1700
Piston Rings - R???
Big-ends - R??
Total R 14800
Also I will have the injectors ultrasonically cleaned at work and everything will be nicely painted and prepped.
I will carry some stuff over from my CA18DET like the FMIC after a piping change the electric fans ,nismo FPR and walbro along with the wideband and stuff
LOL LOL well we can dream cant we
