EGT Temps (Input welcome RAW, Hennie?)
Howzit Guys
I installed an EGT sensor this weekend at the collector before the Turbo , I am seeing the following EGTs
The Highest Recorded EGT after pushing the car was 949 F (509 C)
Normal Crushing is around 700 F (371 C)
I do have a few questions like my EGT temperatures seem to rise slowly when the car is Idling why is this? And what is the normal range for these temperatures?
EGT Temperatures from 1300F ( 704 C) to 1500F (815 C) are common at maximum power mixtures but this can vary considerably
EGT over 1550F ( 843 C) are a cause for concern
14.7 will produce the highest EGT this explains my increase at Idle after cruising also retarding timing will increase the EGT temperatures
Info taken from
"How to Tune and Modify Engine Management Systems By Jeff Hartman"
I am going to have a look at my mounting hardware maybe the sensor is not getting enough exhuast energy or a little loose
Info taken from
Im not knocking your results by any means, just saying that they are quite low in comparison to mine.
If I cruise at 3500rpm my EGT is about 750degrees if I cruise at 4000rpm my EGT drop to 700degrees. All I think of is at 4000rpm there is less load so the EGT drop, any ideas??
Its cool dude,:lol: your not the only guy that’s told me this seems a bit to low by a long margin, I mean those K-Type thermal couples are long so maybe a lot of heat is being lost because I don’t want to restrict flow to the turbo so a lot of the sensor is not in the exhaust stream at it might be looseIm not knocking your results by any means, just saying that they are quite low in comparison to mine.
You could be seeing those EGT because of your timing lets say between 1100 RPM to 3500RPM on very light load in the cruising Zone I’m almost on 40 to 50 degrees
To be honest Xavier, I’m not sure, I mean I’m not the best test bench straying into boost is an event in that car.hey pink i still wanted 2 ask u can u feel a difference with the pully in ur car
But I don’t see why It wouldn’t have work Compared to my old pulley I lost almost 1 KG of rotating mass and thats a Gain in my eyes.
I always believe the Devil is in the details those small thing add up over time
Nope you can get them from Motorbooks in the states but they are available local for around R 500
Sorry off topic, well sort of, Did you order the book online?
I will give you light loadYeah that is alot of timing, what AFR do you run at that timing??
My timing is about 30degrees when cruising at 3500rpm or so.
14.04:1
52 Degress
LOL...
Yep it the truth, on average when driving hard I get around 14l \ 100KM and this is horrible in my eyes the best I have gotten on my tune was 11Km \100
PFB, to much timing and to rich... lean = heat, rich = cool
Gary, to little timing
No need to worry about EGT's unless you actualy understand what your looking at and how it effects the engine, WB02 and knock sensor more than enough.
Remember every single motor is different & that type k's sensor is RIGHT at the tip, unless that thing is placed perfectly your readings could be WAY out just due to poor placement, I use it more as a reference to fine tune timing than a "i need to get to X temp"
P.s. every one of the 300+kw SR20's ive built into full weight SX's get over 10km/L,, the white S13 in CPT with closer to 450kw got 11.5km/L on its way back to CPT... its all in tuning.
