CA18DET:
1993 240 coupe with ca18det
489whp 341ft-lb @ 1.3bar
Engine
83mm CP forged piston with custom trick rings
Pauter rods with rod bolts
OEM bearings (main, thrust, rods)
OEM crank balanced with polished
Tomei 1.2mm metal headgasket
Tomei head studs
Tomei valve single coil valve springs
Tomei 270 duration with 8.8mm lift cams
Tomei adjustable cam gears
High volume oil pump
Yellow Munson porting and polishing
Intake
Yellow Munson custom sheet metal intake with Q45 90mm TB.
Turbo
T04R BB with .69AR on center housing
Streetdynamic custom 3 inch down pipe with mid pipe.
Twin Tial 38mm wastegate with 18psi springs.
Twin 50mm Tial BOV
Custom 4" intercooler
Fuel
Precision 1000cc injectors
Twin GTR R33 dual fuel pumps
Surge Tank
-8an Fuel Line
NISMO fuel pressure regulator
Electronics/ECU
Yellow Munson CA-SR wiring conversion
SR20 Apexi Power FC D-Jetro
Drivetrain
OS Giken twin plate clutch
Streetdynamics subframe spacer
Streetdynamics torque damper kit
Streetdynamics tranny mount kit
Yellow Munson welded diff.(on drag)
KAAZ 2 way LSD for daily and mountain drives
VS
SR20DET
500whp 346ft-lb @ 20psi 93octane
1992 240sx Coupe w/ SR20DET
86mm (Stock) Bore
8.1:1 Compression Ratio
CP 86mm Pistons w/Trick Rings
Eagle H-Beam Rods w/ ARP bolts
ARP Head Studs
ARP Main Studs
Stage2 Streetdynamics P&P Head
Apexi 1.5mm Head Gasket
Tomei 270/270 12.5mm Cams
Adj. Cam Gears
Apexi Drag Double Valve Springs
Trust RAS
Turbonetics T66 Ball Bearing Turbo
-1.00A/R Compressor, .68A/R P-trim Turbine
SS Equal Length Manifold
Tial 38mm Wastegate
3" V-Band SS O2 Housing
3" Downpipe
3" Electric Cutout
Modified TopSpeed Intake Manifold
Q45 Throttlebody
Racing FMIC
Aluminium IC piping
T-bolt IC Clamps
TurboXS Type-H BOV
HKS 200mm Air Filter
4" Intake
1600cc Bosch Injectors
Dual Walbro 255lph hp Pumps
-8AN Fuel Line
-6AN Return Line
-6AN Bosch Regulator
Greddy 4bar MAP sensor
FC-Datalogit
Techedge Wideband O2
Apexi AVC-R
HKS DLI
NGK Heatrange 9 Iridium Plugs
Spec Stage-3 Clutch
B&M Shifter
VLSD
Koyo Radiator
Dual 14" Push/Pull Fans
Eibach Sport Line Springs
Tokico Blue Struts
Greg Dupree Subframe Spacers
Whiteline Bushings
Volk GT-U Wheels
Q45 Front Brakes
Synthetic DOT4 Fluid
Autometer Phantom Tach
Autometer Phantom Oil Pressure
Autometer Phantom Fuel Pressure
Autometer Phantom EGT
Both done by www.rhombus-tuning.com[/list]
