So based on the 6 turbo specs below, which one do you think is best suited to the CA18 and why?
Housing (devided or undevided)
DIV UND UND UND DIV UND
Turbine
exd 49.5 49.5 49.5 52.2 49.5 54.6
ind 64 64 64 61.5 61.5 61.5
trim 60 60 60 72 65 79
Comp.
ind 52.5 all
exd 76 all
trim 48 all
turb AR 0.7 0.48 0.63 0.48 0.7 0.63
comp AR 0.5 all
hp range 300 to 350 all
Ideal CA18 turbo specs
I'm jsut planning for my upcoming ca build. Here are the answers to your questions:Pinkfluffybunnys wrote:Boost level:
Engine modifications:
Power Target:
Responce:
I need those 4 things , This would be interesting
Boost level: low 0.8 - high 1.2-1.5
Mods: Usual strenth/reliability parts. 8.5:1 CR, flow, port, valve jobs etc. upgraded cams & valve train. 8500rpm redline.
Power target: as much as possible!!!
Response: as soon as possible!!!
