After reading allot of info on turbo systems, I am going out and resolving issues with my current set-up, I am still hell bent on attempting to achieve 250Rwhp 186Rwkw on 0,5 bar boost on my set-up so I need to remove all the bottle necks.
One of the biggest trends I have been picking up on allot is the down-pipe outlet is normally never the same diameter as the exhaust system it joins to now an exhaust system in a big generalization in only as good as it smallest point.
Example: if you had a length of pipe and it was all 76mm except for one section being 52mm then there would be a slight pressure build up before the 52mm section as exhaust gasses speed up.
If a Turbo could select its exhaust system it would choose none what so ever but unfortunitly that makes things very noisy for the average guy but by having a correctly set-up system both power and spool-up can be increased a turbo gets its energy primarily from two sources Heat and pressure , Heat can be kept in a tubular system by wrapping the manifold but if you want to make the pressure more effective you have to make the pressure difference more dramatic across the turbo (hot gasses expand and want to fill low-pressure area's a crude example would be 'wind') this would increase spool-up and lowering the pressure between the turbo and manifold allowing an increase in power, lower the DET threshold and is a generally good thing
Anyway now that the science lesson is over
The primary inlet is only 46mm expanding to 52mm
The divorced wastgate pipe is 37mm nice sized
Now this is not that bad if kept separate but they join just before the flange at a 52mm opening plus the wastegate gasses join at a very sharp angle and the wastegate pipe is way to short creating turbulence at the weakest point in the system, Now not to get into to much arguments I still beleave a Divorced set-up in better then a bell mouthed set-up so I will need to make this work
anyway stay tuned because I have a few idea's I need to through past the local exhaust places to solve this issue.
Chances are this might not even make a difference but maybe I will get lucky
